jetboat pumps
Results 1 to 14 of 16
jetboat pumps
    Senior Member slotracer's Avatar
    Default jetboat pumps
    whats the difference in pumps? is it just the bowls only? or are the other difference's?
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    Denton, TX
    Not being an expert, I would have to say the way they flow water, the way the veins are set up & how restrictive they are. I would think intakes are more or less the same not counting shoes ride plates etc. All intakes channel water to the impeller getting it out fast/faster is what I think makes pumps different. Suck and Blow
    Slot check my post on the 1988 "performance boats" thread (jet info)
    lets try this again. what is the difference in a jc & jg pump?.
    slot
    87 eliminator
    Stockton, ca.
    El Cajon, CA.
    Quote Originally Posted by slotracer View Post
    1 letter.
    The JC has a one piece bowl and the JG has a split bowl.
    ok so the pumps themself's are the same, just the bowls are different then.
    slot
    87 eliminator
    Stockton, ca.
    Member Project Bahner's Avatar
    Sep 2009
    az
    so which is concidered better one piece or split bowls
    debatable by application, however the split bowl,or two piece, will allow you to run optional equipment, ie a droop snoot a straight snoot and or thrust angle changing wedges. and also a rooster booster which i beleive is out of production are some of the attachments that come to mind.
    Quote Originally Posted by Project Bahner View Post
    It has been sugested that the c bowl MAY flow a wee bit better. I went with a split bowl because a diverter was/is important to me.....
    Edit: looks like johnray tree'd me.
    H20MOFO its the tinted glasses i can see the green light coming on faster.
    oldsmopile equipped
    Lake Lansing MI.
    you can put a diverter on a one piece bowl.
    oldsmopile equipped
    Lake Lansing MI.
    If you look at the two, the c's veins go almost to the nozzle. with a g, because of the split the veins stop closer to the impeller. so what I have read is the water slows in that area and then re accelerates in the nozzle, killing a bit of efficiency.
    Ive always herd a c bowl is better to about 500hp.
    Quote Originally Posted by Adam View Post
    Hmmmmm I run a droop and a diverter, I didn't think either was possible with a stock c bowl. I could be wrong, but I sure can't picture it ...
    Droop no. Diverter yes
