Reverse cable packer?
Results 1 to 7 of 7
    Senior Member Rain Maker MN's Avatar
    Default Reverse cable packer?
    I see some people sell the reverse cable packer that screws into the berkley transom housing..... are the threads 1/2" NPT ?
    Rainmaker, no the thread is not tapered pipe.
    If your interested heres the "Positive cable seal we make now to replace the OEM style comes in black , blue ,polished Tom
    Redding, CA
    X2 on Tom's fitting here. Is a HUGE improvement over the Berk one.....
    (I have the black one, looks cool too!)
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Member blownt's Avatar
    Houston, Texas
    What about adding a 43BC cable for a diverter? What do you use for adding a cable out the transom? Would like to use something similar to the 45 degree seal Rex Marine sells but it is for a 33 cable.
    Quote Originally Posted by blownt View Post
    Have the same at the reverse packer in a "bulkhead" style for "thru hulls" as well , works well with all the 43 cables including the newer "small diameter jacket cables Tom
    Thread is not tapered pipe, what is it?
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
