Low Profile Intake ??
Results 1 to 14 of 34
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default Low Profile Intake ??
    This is the hot setup.
    Was wondering if it puts the pump into the water out the back of the boat? and more drag but better loading?
    As compared to our boat that is up on the ride plate and nozzle in the air.
    Ours is most definately old school with the superjet intake.
    Just curious
    Looks a little tight to me but it depends on what you are trying to do and the hull type.
    What set up do you have in it now?
    I'm sure other on here can explain a low profile intake better than I but my understanding is that it lessons the entry angle of the water giving it a more direct (straight) path to follow. With the less bend the pump is more efficient.
    This may help as well:
    http://home.pacbell.net/jmcclure/LoProIntake.html
    i've thought about selling the motor outta my nordic, have a low profile intake put in with a small keel over the winter, drop in my lil sbc project and see wtf it'd do. i think the low profile intake with the lesser entry angle would really help my flat keeled tunnel, as i'm sure alil keel would as well.
    fuel, which boat has the low pro and which doesn't?
    Do the low profile intakes help on the top end MPH?
    or more for quickness?
    #55
    New Port Richey, FL
    Yep a gradual turn of the water is much better.
    Maybe I am mistaken about it lowering the elevation of the pump.
    Was looking at a pic of a boat running with a low pro intake and only about half of the bowl is visible, it has a droop with the steering straight out to the tiller. And the steering rod is barely out of the water. So most of the pump is dragging through the water.
    pic is here
    http://dragboats.com/gallery/picture...=13773&RecID=8
    Neither. Both have standard Berkley intakes w/ have have been machined for shoe/ride plate and set by MPD the rigging was done at B1 racing.
    Here another pic
    MPD Low Profile intake:
    Lake Havasu
    So other than the 5* vs 6*, and the loader, how is a low profile intake different from an "R" intake?
    pic is here
    what you're seeing is water spraying out the tunnel next to the bowl. the bowl is not dragging in the water.
    New Port Richey, FL
    Good thanks.
    Thats why I posted up the pic.
    A low profile intake will lower the entire pump, the bowl will nearly touch the ride plate. CS19 posted up dimensions of all the low profile intakes at one time.
    Spiral out MikeF's Avatar
    This is one of the early BayJet modded ones. Intake/engine is set at 6 deg, and at about 2 deg up on the plate......and the droop is "not" below the plate.
    MPD Lo-Profile new in 2008
    An R Intake is a version of a low profile intake. Jack has put up a chart explaining the differences on his website.
