Winter Projects count...
Page 1 of 8 1 2 3 4 ... LastLast
Results 1 to 14 of 102
    Denton, TX
    Default Winter Projects count...
    I'm curious to see what every one is doing to their Hot Rod!
    ill start,
    Totally re-wire the boat
    add a water fuel separator
    Move the overboard dump to the drivers side
    re work fuel delivery system
    Pick up a pyrometer that works!
    add a second bilge pump (float activated)
    New carbs
    New ignition system
    That's all i can think of off the top of my head.
    Senior Member Boost's Avatar
    Pomona ca
    Default Winter project
    Already started mine projecthttp://www.performanceboats.com//showthread.php?t=42188
    Re plume the boat with some XRP stainless hose.
    Change the fuel setup.
    Move motor back.
    Rework the carbs. mill off air horn convert 4160 to 4150 with metering box next year I'll go Quickfuel next season.
    Ceramic coat the headers.
    Change out the chrome valve covers for some alum ones.
    Dallas, TX
    Rebuild seats (vinyl is good but wood is rotten)
    replace the floor
    install battery tray
    Change trailer from floater bar to winch
    clean up the pump
    new emblems
    install drain cocks in block
    install "oooga" horn
    Ladera Ranch
    I need to do a few things too.
    -Pull motor
    -Install new drain hose for oil pan- currently just plugged and it makes a mess.
    -New rails for rail kit and powder coat plates & rails.
    -New intake with backcut MPD shoe so I can try to get my pig out of the water.
    -Learn how to make a plexiglass windshield for the boat since the original is nowhere to be found.
    I need to get to work.
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    lift motor
    remove boat
    install new daytona
    set motor down
    get blown or get blown away
    I'm polishing my "stuff" , pretty "mundane" Huh !
    Denton, TX
    -Pull motor
    That's what i forgot to add. I am going to come up with a system to drain the oil with just a lift of the boat, Like a hose that runs to the bottom of the transom with a bulkhead fitting. uncap/screw walah oil LOL
    Q.C./Big River
    Just a good wash and wax, then cover for 5 months.
    Alamogordo NM
    Quote Originally Posted by Btnhtillidie View Post
    I did a oil drain in mine with a ball valve, a few npt and barb fittings and a power steering hose recently, I just poke the hose out the bildge drain and open the ball valve, seems to work awesome. I dont know if it will work on all oil pans though, my pan had a 3/8 npt plug on the front along with the drain plugs front and bottom. PM me for a pic if your interested
    As for my list:
    replace bow eye
    install lighting
    fab a new ski tow to get the rope away from headers
    Possibly new impeller and wear ring
    get rid of floater bar and install winch and bow stop on trailer
    Alamogordo NM
    I wish mine was that maintence free, seems as if I dont start it up once a week it feels neglected and rebels against me.
    Senior Member n8dawg's Avatar
    Santa Paula
    Oh man where to start.
    New gauges
    Whole boat re-wired
    new gas tanks or fix current ones
    re-upolster seats. would like to go fiberglass buckets and a bench for the back with grey tweed.
    new carpet...maybe, kinda like the wood stringer look alot!
    would like to take everything out but the pump and have MPD go through it. blueprint the bottom.
    rail kit
    re- rig everything with an fittings and braided lines! Get rid of all this Oklahoma style rigged up crap!
    new fuel system
    would like to get a jet-a-way....$$$???
    re-do trailer bunks, paint it white and lower it.
    Re-paint (gel???) boat
    motor freshened up alot!
    So pretty much everything!
    First things first...going to save up for the pump work and rail kit. From there I can do the rest at my own time.
    Next season
    Dallas, TX
    I used a valve from Fumoto with a nipple for a hose. Got mine off ebay.
    http://www.qwikvalve.com/home.php
    plano texas
    Clean,polish,paint,inspect the everything,winterize it,wait for warm weather.
    21' Liberator Jet NORDIC454's Avatar
    BIG D
