Down peddle to run your diverter
Results 1 to 14 of 17
    You Cant See Me slough-cruiser's Avatar
    Kerman, Ca
    Default Down peddle to run your diverter
    Just wondering if anyone has tried this other than myself.
Name:	Cp Gull 013.jpg
ID:	56322   Click image for larger version.
Name:	Cp Gull 021.jpg
    Do it in the water
    Senior Member Futs's Avatar
    Orange CA, Big River
    Seems like alot of work to me. I use a hyd. unit, touch of the finger and it works well. Plus my leg doesnt get tired. But it is kinda cool..
    Quote Originally Posted by slough-cruiser View Post
    Does that spring on the diverter really work?
    The setups I have seen have the springs inside the boat alomg the stringer.
    Brent
    Josh built a left foot "overide" system that worked with his controller for his boat several years back worked quite well Tom
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Yea the dirverter cable hooked to the mechanical linkage of the cav plates.
    New Port Richey, FL
    Quote Originally Posted by SPECTRABRENT View Post
    Brent
    I've used small block Chevy valve springs for that.
    The Man cordog009's Avatar
    East Texas
    Yea I've got a few pics on Photobucket of my old setup, but it won't let me go to that site at work. Will post them up when I get home.
    1984 Youngblood TX-19 SOLD
    How much does all the hydraulic and electrical components weigh?
    I have a manual cable that runs the place diverter and I was going to change it over to a hydraulic system, but I wasn’t sure how much weight I would be adding to the boat.
    Quote Originally Posted by @theRVR View Post
    Well, it doesnt weigh as much as the handle and cable together. I didnt weigh it, but i would figure about maybe 2 pounds.
    Team CJ460 Just Electric's Avatar
    granada hills
    cant be much of a difference in weight between a manual and hydraulic.if your that worried about the weight issue stick with the manual.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Never used a pedal before but I always run my manual diverter oppposite so when you want the rooster up you pull the lever toward you or toward the rear of the boat.
    That way when you mash the gas and you get slammed back in the seat your pulling back instead of fighting the forward motion of the boat
    East Texas
    With no pressure on the left pedal, the pedal is all the way back, and the diverter is all the way up. Push it down to take off, then ease up on it to trim out out where you want it.
    Thrust Whisperer Doc Nozzle's Avatar
    Feb 2009
    What's that bag on the floor in the 3rd pic? Is it for an IV or a catheter drain?
    Morgan Hill
    Built two different ones in the late '90's, they work killer, keeps both hands on the wheel (whitewater boat), the later one used a hydraulic clutch master cylinder from a Toyota truck and a Hydraulic slave cylinder from a Chevy truck (was mosly plastic) with a 20# return spring on the pedal...Mo betta'..
    GT
    GT
