Engine Pre Oiler????
Results 1 to 10 of 10
    not ****** little squirt's Avatar
    Waikiki, HI
    Default Engine Pre Oiler????
    are these worth while investments? who has one or is currently running one? any pics of how you mounted it?
    http://www.engineprelube.com/
    http://www.smartsynthetics.com/produ...mk01-amk02.htm
    http://www.hrpworld.com/index.cfm?fo...ction=category
    thanks
    not banned
    Senior Member Ken F's Avatar
    I'm a firm believer. However IMO this would be a lot better unit, and they are the original. Completly rebuildable.
    http://www.accusump.com/
    Ken
    Boats N Hoes Brad22CP's Avatar
    Northern Cali
    If you have a lot of money invested in your engine then I would say it is a must. I would consider it cheap insurance. These are a couple systems that we have to offer, we also offer the Accusump system but it happens to not be listed on our website yet.
    Good Luck and Happy Boating
    Brad
    Waikiki, HI
    Quote Originally Posted by Brad22CP View Post
    Brad
    thanks, got the shipment from you as well awesome. probably the next investment.
    not banned
    Senior Member HL9000's Avatar
    Las Vegas
    Quote Originally Posted by Ken F View Post
    Ken
    That is the one I run...Works Great...Here's where I mounted mine...
    Waikiki, HI
    thanks for the pic, wasnt sure if you could mount it sideways. phuckin sweeeeet mota by the way!
    not banned
    Quote Originally Posted by little squirt View Post
    thanks
    They may work ok but a good warm up works just great to.
    Ladera Ranch
    Quote Originally Posted by gone4weekend View Post
    You realize that after a motor sits for a few days virtually all the oil has drained back to the pan, right? A small amount of time without oil is murder on an engine. pressurizing the system with oil before startup is a very good idea.
    Waikiki, HI
    guess its time to start saving then.
    not banned
    Las Vegas
    Not to mention also, you get 2-3 extra quarts of oil with the pre-oiler. Mine is on a manual switch and it has a low pressure sensor. If my oil pressure drops below 15 Pounds, red light goes on the dash, and automatically kicks in the pre-oilers stored 75-80 psi and 3 quarts of oil... Its might only be 15-20 sec worth of pressure, but just might be enough time save something rotating...
