2001 19' Eliminator Daytona Project
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 55
    Senior Member s2k1's Avatar
    Default 2001 19' Eliminator Daytona Project, more pump pics added
    This thread will cover the mods and changes I make to my little Daytona. This isn't going to happen over night. It will be a lot of info in a short time, and then a lull, etc.
    I bought this boat in 2006 for $10K basically as it sits. I have been told that it was originally rigged by GS marine for a customer in Oklahoma. Original power i'm told was a 600" BBC on NOS. Sometime after it's birth, it was traded in at DCB. I believe it was repowered at DCB, and some other hardware was removed/replaced. I bought it from the 2nd owner, who bought it from DCB. The 2nd owner didn't know anything about it and used it very little.
    Here it is now........
    Chris @ Benchmark Performance
    B1 Racing cs19's Avatar
    Nice daytona, looks like a good boat to work with, Good luck with it.
    B1Racing.net
    Some more pics, trying to show the keel.
    Senior Member coonass's Avatar
    Canyon Lake, TX
    Real nice man and you stole it for that price what mods are you think'n of
    Those pics taken just outside of Blythe? Looks familar.
    B1Racing.net
    Yuma.
    Check out the crack I discovered yesterday in the keel. It is right before the intake and can be seen in the pics above. Is this a major concern? Water worthy one more trip?
    Team CJ460 Just Electric's Avatar
    granada hills
    nice start.boat looks to be almost there im sure with a little tweaken it will haul the mail
    Canyon Lake, TX
    Quote Originally Posted by s2k1 View Post
    Yuma.
    I notice'd that......................make sure to keep an eye on that if you run her again...........nothing good can come from the intake come'n off at any speed or might make the crack bigger ..........my.02
    Senior Member Hustler's Avatar
    Tujunga,ca
    Nice boat and a great project. I have seen cracks like that before around the intake, it's from when the bottom work was done and the speed coat, I'll bet that it has been there for a long time.
    San Diego, CA
    Yuma.
    Nothing to worry about, they all do it when you add a keel like the one pictured. I'm sure some of the other guys around will chime in. Typically they crack through the keel added portion not through the boat.
    Boat 405.
    Spiral out MikeF's Avatar
    Looks like you have found a real nice boat that you kinda fell into......that's a score!
    Those cf#'s gotta go!
    Good to know. I'll definitely keep an eye on it.
    What is the deal with the stringers in my boat? As pictured, they get shorter in height between the back of the seats and the front of the engine. Are all 19' Daytonas like that?
    Also, I am wondering about engine placement. Is mine pretty far forward for a low HP motor? If I measure from the transom to the back of the block (haven't done it yet), are there some setups in other 19s I can compare it to?
    Right now this thing will only do 53mph. It breaks water right at the helm, so I know there is a lot of drag. I also know more power will help, get the boat out of the water more.
    Quote Originally Posted by MikeF View Post
    Ya think???
    What is your rpm at 53mph?
    The shorter stringers accomodate a rear seat.
