Jet-a-way Question
Results 1 to 14 of 14
Jet-a-way Question
    not ****** little squirt's Avatar
    Waikiki, HI
    Default Jet-a-way Question
    im sure duane will chime in, just want to know if these unit require any annual or recommended services? or are they pretty much a sealed unit and only require something if something goes wrong? thanks, just bored at work and thought i would throw this question out there cause i dont know the answer.
    not banned
    Colfax, Ca
    There is a dipstick on the drivers side of the unit. Small plug, unscrew and check the level.
    The Right Coast/SE-PA
    Quote Originally Posted by little squirt View Post
    The prior owner (Jetmech) sent your Jet-a-Way to Duane for a rebuild...(very little time on that thing) other then checking the oil it should be fine for years of service.
    Waikiki, HI
    10-4 didnt know about the oil level dipstick. thanks guys
    not banned
    Senior Member Ken F's Avatar
    It's not a dipstick, it's an oil level hole like on a differential.
    Ken
    Waikiki, HI
    Quote Originally Posted by Ken F View Post
    Ken
    Thanks for the clarification.
    not banned
    Colfax, Ca
    Mine has a dipstick
    Fleet, that's a new one on me. Guess we'll have to wait for the "D"man to show up.
    Ken
    Ken
    Mines got a site hole too, fill it let it sit and settle, then recheck fluid level.
    Shell Knob, MO
    The early models had three holes in the case. Top hole at 11:00 o'clock is the fill hole on all models. The side hole at 2:00 o'clock is the check oil level hole on all models. The early models had another hole at 5:00 oclock that the spacer pin went in to. At serial #4050 we stopped putting the pin hole in the bottom and moved it to the 2:00 o'clock position. This pin is a must to hold the bearing spacers in place. This threaded pin also serves as a dip stick. As long as you can stick it in, (not screw it in), and touch oil, the oil level is okay. Hope that clarifies the issue.
    Thanks for the reply Duane. Damnit, I learned something today...hate it when that happens! LOL
    Ken
    Waikiki, HI
    so what do you use (oil, type, wieight) as far as topping off the oil level if it needs to be done?
    not banned
    Member jetmech's Avatar
    Cecil County MD
    gear oil ... Your unit is good to go charlie ... maybe 1/2 an hour of run time on it.Contact Duane ... they can send you the correct fluid.
    Bob
    Waikiki, HI
    cool, thanks bob.
    not banned
