Type of shoe
Results 1 to 14 of 42
Type of shoe
    Feb 2009
    MANTECA
    Default Type of shoe
    I have an 18' Rogers jet and I am wondering what would be the best shoe to run on it. Flat, Tapered, or Backcut.
    If you have a rogers and don't mind sharing what works for you I would appreciate it.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Quote Originally Posted by bigdog View Post
    I had an 18' Rogers Bonneville not set back, with a flat shoe, 13" mouth opening, the shoe depth was a 1/4" in the hole. full open center loader
    the boat ran alright for the minimal power that I had.
    Dont know what the nozzle was @ (Place diverter) but the plate was @ 4 deg.
    Fun boat to drive!
    B1 Racing cs19's Avatar
    back cut shoe
    B1Racing.net
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    That depends on the HP, pump ,nozzle location and the weight of the boat/driver.
    Senior Member bp298's Avatar
    LHC
    back cut
    Senior Member ironman's Avatar
    Clovis CA
    Now when you guys are talking about the mouth opening that is from the back of the horseshoe to what other point ? just tryin to learn ...
    Ironman
    And what is a flat shoe??? Edit: I guess that's a dumb question...but seriously it has NO biting edge??????????
    Senior Member Tony Skagen's Avatar
    From the loader pad to the center of the shoe.
    www.skagenboats.com
    Feb 2009
    MANTECA
    I guess that would depend on how the machine work was done on your intake and how it was set in the boat. I would consider a flat shoe to be one that when installed the bottom of the shoe is on the same plane as the keel of the boat. This seems hard to explain but if you took a digital level and put it on the bottom of the boat it would read the same as what a flat shoe would read.
    This is what I consider a flat shoe to be, but there may be different opinions or definitions for a flat shoe. Just my $0.02.
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    I've been told that the Rogers like a back cut and will help free it up. Got to do it to mine soon.
    LHC
    a flat shoe is a flat shoe - same thickness at the front and back. a tapered shoe is thicker at the front than the back (angled down toward the front), backcut is opposite, angled down toward the back.
    4th picture down on the following link...
    http://home.pacbell.net/jmcclure/ShoePlate.html
    That means it is flat sitting on you work bench but may not be flat in the boat in relation to the keel.The surface the shoe bolts to may not be on the same angle as a intake in another boat.So it is hard to say flat,tapered or back cut until you know where the mounting surface is.
    Shell Knob, MO
    Just to clarify a bit; The shoe itself is either a tappered, a flat or a back cut shoe. The way the intake is cut or the angle at which it is mounted in the boat may give a different end result when installed. An easy way to find out what the end result of what you may have is to put a ditital level, (or whatever kind you may have), on the keel of the boat. Raise or lower the trailer jack until the level reads 0 degrees. Then put the level on the shoe and see what it reads. This will tell you the end result.
    Duane HTP
    Duane HTP
    Thanks for that description Duane....I'm not even going to tell you what I though it meant.
