Intake Setback
Results 1 to 6 of 6
Intake Setback
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Default Intake Setback
    I did a search and can't find the answer, so here it goes.
    How do you determine how far back to set back the intake? Is there a rule of thumb?
    Thanks,
    Wags
    Sacramento, CA, USA
    Another question that has stumped the pros???
    Wags
    Breathing Diesel Shotgun19's Avatar
    Michigan
    Setting the intake back has to do with alot of factors, And one of them is who and how the boat is being set-up, What type of hull it is, What type of hardware you are gonna use. Some people like the hand hole outside the transom and some dont.
    Sacramento, CA, USA
    1975 Miller, 19' with 460 BBF. Berkeley JG pump with a 6" droop, 4* wedge, and a hydraulic Place Diverter. Intake will be milled for a shoe and ride plate. Hand hole out side the hull.
    Wags
    Las Vegas, Nv
    Greg , I am By no means an authority on Pump setbacks, But what determined how far back for me was 1) I wanted the handhole outside the transom and 2) All of My research lead to the understanding that I wanted the biting edge of the shoe as close to the back edge of the keel at the transom ,as I could get it, without going past. Just to clarify ,there are some who intentionally set the shoes bitting edge further back than the edge of the transom.
    I did talk with Jack McClure on the subject and that is where He had sugested....Hal
    The intakes can be machined, to allow a farther set-back without cutting the transom.
