Daytona info
Results 1 to 3 of 3
Daytona info
    Sacramento area
    Default Daytona info
    I have a 19' Daytona 450#, 685hp that need to be completely rigged. The information I'm looking for is what type of intake to run? I have Berkeley "R" modified to take the standard loaders. I have a low profile "GTH" 4deg. Or the standard 4deg Berkeley.
    Also where to set the mouth of the intake, in relation to the transom, Even?
    The boat is going to be used to lake race.
    Any shared info that has worked for you is appreciated.
    Be safe, schick
    what keel does it have? spend some $$ with a good pump person.
    like MPD, Jetboat performance, or anyof the other pro's and they will steer you in the right direction.
    #55
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    I agree, ask the pro's
    Duane at Hi-Tech performance got my heavy 21' daytona to do 118mph
    Pump work, bottom work, it all helps
