Carb Linkage
Results 1 to 14 of 17
Carb Linkage
    Idaho Jet Craig4937's Avatar
    Aug 2009
    Default Carb Linkage
    I'm still new to this tunnel ram linkage... I have a holley mounted to a tunnel ram with a side mounted carb linkage plate. Is it better open (push) the linkage from the front or the rear of the motor?
    Craig
    Kingman/Golden Vly, Az
    Quote Originally Posted by Craig4937 View Post
    Craig
    1x4 or 2x4 TR?
    FastRat
    Aug 2009
    Its a 1X4 tunnel ram....
    Craig
    Craig
    it is better to push the throttle open from the front, that way u keep everything in a straight line ...on a side note...why a 1x4 TR?...u would have "much" better performance with a 1x4 Edelbrock RPM Air Gap manifold...1x4 TR's tend to puddle in the corners & cause trouble!...i had 1 on my motor & it worked fine at w.o.t., but not at low speeds or idleing around ...chnged over & much better overall...just trying to help ...just my .02 cents
    FastRat
    Aug 2009
    My issue is that the side mount carb adapter makes the cable sit at an angle to the linkage and is not a straight shot. Did I get the wrong plate? It looks like a standard holley carb.......
    Craig
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    Craig
    Put up some pics if ya want help.....
    Member bakerjet's Avatar
    i also went back to a performer RPM, the tunnel ram looked cool
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    Quote Originally Posted by bakerjet View Post
    Went the opposite way, from a Performer RPM to Tunnel Ram.
    Linkages and carb mounting were a quagmire for my lil brain, but after some figuring with a sideways mount linkage, I was able to get the twin 750's mounted inline.
    Baby brother's working on milling out a better looking mounting system, a lil hilljack, but it works, and everything is inline on the same angle
    Ray
    Rebel...
    i sure hope that set-up works out for u, cause u have the rear carb turned around backwards???
    u would be better off if u mounted them sideways!!!!
    just my .02 cents....good luck
    FastRat
    Aug 2009
    Default Carb Linkage Issues
    Here's some pics. I know it doesn't look like it but, the ball joint is probubly 1" or so away from the linkage which puts it in a bind...........
    Craig
    Aug 2009
    Well I can't figure out how to get these damn pics in here!!!!!!!!!!!! HELP! I copied them to photo bucket and tried to upload the url......Didn't work... How come it's so hard to load pics on this site??????????
    Craig
    If any body could help please.............
    punk ass kid warpt71's Avatar
    LHC, AZ
    I'll paddle my flat before I drive anything else!
    Aug 2009
    Default Pics
    How'd you do that!!!!!!!!!!!!!
    Craig
    LHC, AZ
    I opened your photobucket and copied the properties of the picture and pasted it between the image code, [ i m g ] [ / i m g ] (no spaces!!!)
