Hole Shot
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 50
Hole Shot
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Hole Shot
    What are some of the ways to set a boat up for a good hole shot? Weight and the size of the impeller seem the most obvious.
    What motor etc and where does it make power ?
    Preloader...More lower end-stroker
    Made In The Shade
    Custom Window Tinting
    Charlotte, NC.
    I dont know the answer but i bet it differs depending on your application. Some real smart guys on here. Give as much detail about your ride as possible and they will give you some good advice.
    Senior Member W.O.T's Avatar
    Campo Ca
    Big Impeller. Inducer. Less Weight. Diverter Down. Open Loader.
    Q.C./Big River
    Quote Originally Posted by W.O.T View Post
    x2
    Campo Ca
    x2
    I Would Like To Have One. Im Running A B/C Impeller With An Open Loader. I Wont Even Try To Get On It From A Standstill. Cavitates Like Crazy.
    Lake Havasu
    Will an inducer hurt top end? Is there any negative to having one?
    Q.C./Big River
    Quote Originally Posted by Master Sergeant View Post
    Not at all. There are some made that I don't have any experience with. I know for sure that the ones from D.P.S. will not hurt top end.
    Senior Member JDG911's Avatar
    MESA
    i have been experimenting with jay from MHP in mesa and we have been having good luck with my little boat. i had a center blocker with a droop and it really hurt my hole shot. now we went to adjusting the ride plate 2 degrees up with full open loader c impellar 3inch id nozzle with srtaight snoot witch had 4 degrees in it then added 6 more derees of wedge. it is just all trial and error evry boat is different.
    MESA
    i do have a inducer and with doing this and still learning cause i dont know it all when gassisng it from a stand still load the pump then nail it. it should take a good set and run like a sob out the back end
    B1 Racing cs19's Avatar
    We are all stuck with the weight of the boat, not much you can do there. The biggest things are a well blueprinted pump, a good shoe,bottom and more imporantly loader combination. Applying just the right amount of power that the pump can handle and one of the biggest things is gettting the boat up and clean without draggin the boat up onto plain or without bouncing all over the place trying to take a set (place diverter with up and down stops is key here)
    B1Racing.net
    MESA
    see im 16ft so i have to do things different but i have noticed some guys with 19fters use a 2 step relay on there pumps and man those guys come up on plain and move where i have to burp the motor roll the boat over and just when the nose starts to come down nail it and at the same time hit the nos and it takes a great set and runs strong. i got to play with it at parker this last weekend with blown jet 13 and with all his expierence he really helped a lot with showing me how to really run this boat and for that im greatfull. hats off to you jay
    Senior Member brgrcru's Avatar
    Montrose
    JDG911, We saw you Saturday. We were up at Riverlodge with a white and red CP and a light blue flatty. We saw you go up and down, but didn't see you the rest of the weekend. Was nice to see a few Hot Rods on the strip.
    Sorry about the jack thread. But if hole shot is what your looking for MPD is my answer.
