Has anyone experimented with light or heavy flywheels in Jet boats?
Results 1 to 10 of 10
    Senior Member Daddy B's Avatar
    Question Has anyone experimented with light or heavy flywheels in Jet boats?
    I have a 50 lb flywheel, a 35 lb flywheel, and a aluminum fly. The motor is a healthy 427 bbc 11.5 comp., going in this 21 fairly light cruiser. Just curious if there would be any noticable differences. I thought the 50 might give me a little more torque but I really don't know. Any experience out there.........I got a feeling someone has tried it......Thanks ahead of time.
ID:	57681   Click image for larger version.
    Morgan Hill
    Quote Originally Posted by Daddy B View Post
    All depends on what you're going to do with the boat...
    I like light flywheels (aluminum) because of the rate of decel (play on rivers and good throttle response is required).
    A heavy flywheel can help prevent overreving the engine when you vent the pump, but otherwise don't know of any more positives one way or another....
    GT
    GT
    Shell Knob, MO
    Go with the light flywheel. The pump shaft and impeller are already acting as a flywheel. Why add more weight to the boat?
    Use a flex-plate for a automatic trans. Lighter yet.
    X 3 use a good flex plate (SFI) also employ a rev limiter...
    Keyword "good quality" you havent lived till you've thrown a counter weight
    Monroe, WA
    I've tried both ways with my mild Oldsmobiles. Maybe a tad bit quicker accel, hard to tell. I thought I'd really feel a big difference, but no.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Senior Member OUTLAW HALLETT's Avatar
    SHASTA LAKE CA.
    that 427 shouldnt have a counter weight,,,should it ?
    Well, That's easier, I have a good quality flex plate on it, and the whole motor is perfectly balanced so maybe I'll just leave it on there.....I wasn't sure if I could run a flex plate only. I wondered if a heavy flywheel would give it more rotating mass and give me higher rpm's and slightly higher mph. The motor is coming out of the v drive. I am going to change to a different cam, with lower rpm range.
    Thanks for the feedback.
    I still don't know what impeller is on the thing.... might be a or aa. Is there a easy way to tell what size of impeller?
    Orlando.FL
    I ran a flex plate back in the 60ts accelerates faster and when off the peddle stops quicker. It came in handy when running against a first timer in the turns and anywhere else.
