water pump
Results 1 to 8 of 8
water pump
    Default water pump
    do i need to run a water pump on a jet boat? I have a chevy 350 small block.
    Senior Member superdave013's Avatar
    the big white thingie in the back that's hooked to your engine IS the water pump.
    thanks...... I am going tom have a bunch of stupid questions. Im building my first boat...Please bare with me.thanks for the info.
    not ****** little squirt's Avatar
    Waikiki, HI
    Quote Originally Posted by superdave013 View Post
    not banned
    Waikiki, HI
    Quote Originally Posted by alldoza View Post
    sorry but had too, didnt see this post when i posted.
    not banned
    i would have done the same..........
    you do need to regulate the water pressure. look towards the back of the boat on the lh side, you should see a pipe coming from the pump, that's the water supply for the motor you do need to regulate it down to no more than 20-25psi of pressure. otherwise you'll be seeing water in your oil, etc.
    Southwest corner AR
    Alldoza, All questions deserve awnsers no matter how big or small! Some peeps are stupid not to ask questions at all! Good luck with your new boat!
