hopping at top speed
Results 1 to 14 of 18
    MPR FAB southwind011's Avatar
    riverside ca
    Default hopping at top speed
    my southwind starts to hope at about 65-70. i put a diverter on it, helped the problem but still dose it. what can i do to get it to stop
    Morgan Hill
    Quote Originally Posted by southwind011 View Post
    Not enough info. to tell you bro.
    Possibly a ride plate, could be as simple as weight distribution in the boat.
    Got pictures of the setup?
    GT
    GT
    slow down. Like they say Dont do that. Dont you hate a Smart Ass? I had one like that and it was due to the drop I put on the pump. I ended up putting 60 pounds or so in the front to fix it. The drop still gave me apx 10 mph faster even with the weight in it.I bet someone here will tell you how to fix it right. Good Luck.
    Tempe/Big River
    i was messing with my ride plate this weekend and experimenting with the shims there i found a hop with a certain amount and was able to get rid of the hop by shimming mine up
    riverside ca
    the boat comes out of the water and the pump cavitate, some times the motor will hit the rev limiter
    Does your boat have any plates on it at all? What has changed recently? Or is it new to you?
    riverside ca
    no ride plates and the boat has done this since i bought it.
    Morgan Hill
    FWIW, that is not a Diverter and could be part of your issues. What you show a picture of is a Jet O Vater and don't work nearly as well as a Place Diverter.
    With that set up, i would be suprised if you could get it to work much better, especially at 65 plus.
    My little jet has a Place diverter and made close to 500 HP and would do just a tick under 85 but the slightest little ripple would upset it and then you were chine walking and looking to get out of the throttle mui pronto.
    The boat now has a much milder motor and a different pump setup and I could not get it wet this year, but betting it will still get to at least 80, and I will be able to drive it.
    Some boats just react different with more power. I like the weight in the bow idea.
    GT
    GT
    riverside ca
    GT
    i found the thing for a $100 so tried it but i think i just need to spend the money and get a real diverter. would a ride plate be a good idea. i am going to be striping the boat down to paint it,would setting the pump back do anything for me.
    Well I would put some plates on it myself. Do like I said and Mr. Jet thinks and put some weight in the front. Like I said I only had about 60 pounds in the front to fix mine.
    riverside ca
    do i put the plate under the pump or all the way across the transom. did you ues lead bricks or steel plates
    Morgan Hill
    Setting the pump back may take care of the venting of the pump, but should buck even more (takes a bunch of HP and tuning to get it to work) and IMHO would be a futile effort.
    Get a late style Diverter and I think you will find a dramatic improvement over what you have.....Mainly because of the Diverters built in ride surface. It really calms them down.
    Good luck with it.
    GT
    GT
    Morgan Hill
    Two cases of Coors light cans... The proverbial silver bullets
    GT
    GT
    riverside ca
    thanks for everyone help, i owe you guys a beer
