Shoe question
Results 1 to 14 of 26
Shoe question
    You Cant See Me slough-cruiser's Avatar
    Kerman, Ca
    Default Shoe question
    Ok I currently have a shoe that is 1/2" thick. My question is would I be able to get a little better mph by going with a 5/8" or 3/4" shoe. If you had to choose wich one should I try first. The boat is a 19' Condor (like a CP). With a MPD 080 101 intake. I am currently running an a/b ss impeller with droop and place diverter with a 3 1/8" nozzle and loader. Boat is running between 82 and 85 mph depending on air and h2o conditions. Any advice would be much appreitiated.
    Do it in the water
    eay way to find out is try shims, usually just .025 -.030 at a time. 1/8 - 1/4 at a time is huge, needless to say dangerous. You have to sneek up on your set-up, it it could end in a bad way.
    Spiral out MikeF's Avatar
    Take the nozzle out 1st......easiest change, to see what that does.
    What rpm are you turning at 82/85 mph?
    Kerman, Ca
    Default Rpm
    It is turning 5600-5700 rpm.
    Quote Originally Posted by MikeF View Post
    Do it in the water
    Quote Originally Posted by slough-cruiser View Post
    Your a/b impeller rpm does not match up to your speed (amount of water moved)....... You're losing something somewhere. A typical vbottom boat (good bottom)(solidly built pump) will gain about 10mph per 500rpm.
    By your first post.....it is a flat shoe?
    Pump pictures?
    Piedmont, OK
    Is it a TX-19? Is the shoe below the keel? If so how much? Start off slow, if you drop the shoe below the keel to much your asking for TROUBLE!
    Kerman, Ca
    Default Heres some pics of the pump and the bottom
    Hope these help.
    Pump pictures?
Name:	TX 19  bottom 001.jpg
ID:	58364   Click image for larger version.
Name:	TX 19  bottom 003.jpg
ID:	58365   Click image for larger version.
Name:	TX 19  bottom 005.jpg
ID:	58366   Click image for larger version.
Name:	TX 19  bottom 010.jpg
    Do it in the water
    Kerman, Ca
    Default One more ?
    What RPM should I be turning with my a/b. My pump spins up to a little over 6000 and then hooks up. It seems to leave pretty well. But if I can make it leave better that would be great.
    Pump pictures?
    Do it in the water
    About 90+.
    My opinions on what to do.........in order.
    1. Buy cheapy degree measuring tool.
    2. Add strengthening rails to your rideplate......looks bent (by water force).....straighten (via support rails) and raise to 5deg up min from keel line. (likely more later)
    3. Backcut shoe....mpd (as you said that is where the intake came from)(be ready w/ dimensions of your shoe for Jack)
    4. Remove wedge.
    5. Adj and take note of where each notch on the diverter handle "places" the diverter at......and "speed" run the diverter at 5 deg up....then adj accordingly up a little more until your best result.
    6. Grind off the bottom of the lower part of the "vertical" stingers on the loader.....square or slightly up to the "keel line". (details, details)
    7. Take notes.....and continue to adjust and record results.
    That's where I'd start.....and stay safe......be sure of your surroundings!
    Kerman, Ca
    Default Thanks for the input
    I only have one ?
    I just put the wedge on the boat. It picked up about 2 mph. Do you think its ok for know, just untill I make some of the changes you suggested.
    About 90+.
    4. Remove wedge.
    Do it in the water
    Ok.....leave wedge in.
    Take notes......
    Remove nozzle......
    Continue moving forward.
    Another thing......make sure there is enough threads engaged in/on the turnbuckles for the ride plate to keep it from pulling apart.
    Safety 1st.
    Kerman, Ca
    Default Thanks mike f
    Will give it a shot and see what happens. Thanks again for the help.
    Quote Originally Posted by mikef View Post
    another thing......make sure there is enough threads engaged in/on the turnbuckles for the ride plate to keep it from pulling apart.
    Safety 1st.
    Do it in the water
    U Kno It OMEGA MAN's Avatar
    Kerman, CA
    Take the wedge out. The boat ran 85 in Bako without it.
    SLOUGH CREW
    U kno it !
