Widowmaker quick question
Results 1 to 8 of 8
    Default Widowmaker quick question
    Kjell how many qts of oil did you run in that Stefs Pan?
    I'm bolting it up and figured I would mark the dipstick where you used to run it. Should be a good starting point.
    Paul
    #55
    San Diego, CA
    Run 7 quarts in the pan. 1 in the filter. Does this mean you're getting close to firing it?
    Boat 405.
    Senior Member W.O.T's Avatar
    Campo Ca
    Just Curious How Many Qts Is The Pan Capable/Said To Hold Normally?
    Campo Ca
    I Ran A Milodon Pan And Had Oil Psi Issues. Now Im Running A Pan From Jet Boat Performance. No Oil Psi Issues. But When I Run 10qts, My Motor Makes A Mess. If I Run 8-9qts In A 10QT Pan Im Good To Go. No Oil Spray.
    Thanks....Means the engine is DONE Talking with my EFI guy about putting it on a dyno
    WOT specs show 9 qt pan, but Widowmaker has ran this pan on a dyno
    and in his boat so I figured he had a good idea where it worked best
    #55
    San Diego, CA
    Quote Originally Posted by W.O.T View Post
    Its a custom box, full length kickout aluminum pan with a rear sump from Stefs.
    Boat 405.
    here's a pic
    #55
    San Diego, CA
    here's a pic
    Looking good Paul
    Boat 405.
