pressure regultor
Results 1 to 14 of 14
pressure regultor
    Maple Ridge B.C. Canada
    Default pressure regultor
    my regultor off my berg jet is broken up. I need either a spring & seat or a new one. I can't find them on-line.whats a good one & who sell's them ?
    Thanks Don
    please check your PMs
    NICE pic btw
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Duane at Hi-Tech sells them
    Scroll down over half way down the page
    http://www.hi-techperformance.com/HPParts.HTM
    Quote Originally Posted by rogerroost View Post
    Thanks Don
    just run without 1, it'll be fine. just make sure you have bigger outgoin hoses coming outta the motor than what's goin into it
    I found a 3/4 pressure relief valve at our local Atwoods farm store for $27, it is made by W.L. Hamilton Co. part# 2053-1.
    Quote Originally Posted by cjaj70 View Post
    that one will work fine.
    so what kind of pressure should the cooling system be running at?
    18 psi. Make a manifold with a guage ,hook it to a garden hose and set it running. Set at 16 to 18 lbs opening. Stake it with a center punch.
    The one i used has a higher pressure range than i needed but has worked perfectly so far.
    Senior Member cbcp's Avatar
    Carlsbad
    Does anyone make a billet aluminum regulator for this type of application? Or is the pressure to much?
    saw one on banderlog forums, was cast aluminum, but they took it to a wheel, and polished it up, looked billet.
    Carlsbad
    Can you post a link?
    Thanks for the input! I was getting water in the oil.this may be the problem.I would have expected low pressure with a broken spring ,I guess it was jammed .There is a gauge on the manifold,that doesn't work also. glad I got this boat at the end of summer,lots of time to whip it in to shape
    Alamogordo NM
    Judging by your avitar I would say her shape is just fine
