berkeley 12JG oil fill?
Results 1 to 12 of 12
    Nov 2009
    Default berkeley 12JG oil fill?
    I have a 12JG berkeley and pulled the two plugs on top of the bowl to ad recomended 90 wt to it, and according to most discussions I've read... the oil should come out the oposite hole when full! but it never did that.. it just started to drip out of a small hole on the underside/bottom of the bowl, I put almost a quart in and about a half pint dripped out of that hole and it quit. does this indicate some sort of a seal problem in the bowl because it didn't just come out of the oposite hole, or is that normal to seap out the bottom hole when full? Thanks
    Morgan Hill
    Quote Originally Posted by tablerockjet View Post
    I don't think there is a problem with the seal, I think it's missing...Those bowls only hold a few ounces of gear oil....
    IMHO the bowl needs to come off to investigate the issue.
    Dont put the boat in the water, you will make a Valdez sized oil slick.
    GT
    GT
    Shell Knob, MO
    Where exactly is this hole located on the bottom of the bowl that the oil is dripping out of?
    Like GT said, don't run it until you find out what's going on here.
    Nov 2009
    it's just a small factory hole on the bottom side tword the front of the bowl
    Shell Knob, MO
    A "Factory Hole"? That's a new one on me. Any Pictures?
    Duane HTP
    Nov 2009
    hang on a couple mins I'll try to get a shot
    Nov 2009
    here it is..
    Nov 2009
    that's the bottom front of the bowl, Hole!
    Morgan Hill
    Not factory IMHO...Someone drilled a hole to drain the bowl...I have seen this before but normally a threaded hole where they install a set screw to act as a plug...
    I see it mostly in the Northwest, I guess because of freezing...You could remove that bowl in under an hour and it would only cost you a new bowl gasket and your time to get to the bottom of your issue.
    Cheap insurance.
    GT
    GT
    Nov 2009
    Thanks GT, this boat came from Lewiston ID.. so I'll bet your right!
    Quite possible some that bowl had a cable "anchor" for a "clandestine trim system" at on time or another or perhaps someone simply created a "bowl drain" but not "factory" I'd just fab up a plug for it and call it good.. Tom
    Shell Knob, MO
    That's why I wanted a picture; I knew something didn't sound right here! Thanks! Just repair the seal and plug the hole x 3. Duane HTP
