WTB Transom cover
Results 1 to 14 of 29
WTB Transom cover
    Nov 2009
    New York
    Default WTB Transom cover
    Looking for a deep Aluminum transom cover for a set back pump installation.
    Senior Member JDG911's Avatar
    MESA
    Quote Originally Posted by z racing View Post
    looking for a deep aluminum transom cover for a set back pump installation.
    depending on how far you set it back you more than likley will have to make it like this one that i did
Name:	Pump set back.jpg
    Nov 2009
    New York
    What you made would work for my application but no time to fabricate one. That is why I was trying to find one to buy. Too many projects going at once. I drag race pro bikes, snowmobiles, boats, anything fast. Thanks for the reply if you hear of anything let me know.
    Senior Member lbhsbz's Avatar
    Long Beach
    Quote Originally Posted by Z Racing View Post
    I've got a fiberglass one...not too pretty but it's about 8" deep I think. Needs a little bodywork but it'll do the job. I'll send you some pics tonight if you want. PM me your email address.
    B1 Racing cs19's Avatar
    Your going to be stuck with the deep fiberglass one if you dont want to fab something up. I think GS Marine has the mold for that piece, if not he knows where to get one.
    Chris.
    B1Racing.net
    Nov 2009
    New York
    Chris.
    Thanks guys, i ended up staying up late last night and have my template made. Dave at CP talked me into it and has told me what i need to do. I do have one question. Should i make my aluminum plate out of 1/4 inch or what would be best? Thanks for the responses. You all have been a big help.
    Tom
    Z Racing
    Only needs to be 1/8th inch, or .125 thick. I've made them from .250 and .200 aluminum before, my current deal is .200 thick. If your mounting your steering tube on it, with the berkeley cut out, you may want to go with a minimum of .200 to reduce flex IMO. A pump brace is also in order, you won't have the extra support of the transom adapter.
    Default transom cover
    i have a deep polished transom cover, Jim
    3/16 minimum for the aluminum plate. 1/4 is fine.
    B1Racing.net
    Nov 2009
    New York
    Thanks for the input, I am going to go to 1/4 inch aluminum. Do you have any pics showing pump braces. I am also going to weld a plate on the inside of the transom plate for the steering tube to make the same thickness of a stock berkeley cover. Thanks Tom Z Racing
    Nov 2009
    New York
    Quote Originally Posted by Jim Brock View Post
    Thanks for getting back too me. I have made and went with flate aluminum plates. Thanks Tom Z Racing
    Nov 2009
    New York
    Thanks I am going to go with the 1/4 inch plate. Thanks Tom Z Racing
    Young Junior Member
    Sep 2009
    BBL
    how much more power does that really give you?
    and is it worth the time, effort, money, ect.?
    As far as the pump brace pics..do a search for" let's see your pump braces" there is a few threads that come up. I'd do a link if I knew how.
