intake fins
Results 1 to 7 of 7
intake fins
    Aug 2009
    Default intake fins
    broke a fin..bought gps...82.3...broke the other one off...2.2 faster... now what
    San Diego, CA
    It will probably hunt, side to side at high speeds.
    Boat 405.
    California
    The intake will load really hard with no fins, be careful
    Morgan Hill
    He can always fashon up some smaller fins on the shoe....
    Grind the old fins down smooth and get a finned ride plate, or a custom shoe....And don't try to out turn someone...
    Another "White guy" fix would be a turning fin before the intake (like 4-5' without seeing your boat)..
    We have broken, or should I say worn them off before without noticeing...Interesting numbers....
    GT
    GT
    Senior Member Futs's Avatar
    Orange CA, Big River
    Did you do the runs on the same day? Air will help or hurt you, as will water conditions.
    HMMM no fins get dicey over 70, be careful. If the intake has not been out in recent history, may consider removing it for repair, then resetting the intake.
    Aug 2009
    the boat drove the same as usual...straight and fast.i didnt know anything til i got home. but the intake is cracked all the way around so a reset is in order..are these repairable...whats the scoop on all the diff intakes
