Can this be fixed????
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 55
    Santa Clarita
    Default Can this be fixed????
    Maybe with a blow torch and a big hammer????
    Canyon Country, CA
    No need to fix. I have heard that design helps reduce windage in a wet sump pan when used in conjunction with a Dooley kickout pan. Just order a custom piston with compression height adjusted to set it at zero deck.
    Is that yours?
    Senior Member sleekvino's Avatar
    that is a new Al Gore design it give it a lower compression to help out the planet.
    PORNO RACING INC WHERE ITS "HARD" TO WIN
    The Right Coast/SE-PA
    My 'rod' bends to the left
    if its from a ford the the only fix is to buy a chevy.
    that's too much info hammerdown lol
    good rod though if if bent that much without breaking
    Lurker
    NC
    x2!!!
    San Diego, CA
    that shit will buff out.
    Boat 405.
    B1 Racing cs19's Avatar
    hydraulic'd the motor? What happened?
    B1Racing.net
    Las Vegas, NV
    drink until it looks straight.
    Quote Originally Posted by Brad @ SCJB View Post
    true man of genious
    Spiral out MikeF's Avatar
    I get it.....that's what the ford guys do to get the longer crankshaft in there!
    Glendale Arizona
    Wonder what would've happened if it were an H beam rod instead. Probably would've been worse off.
    Anza, CA - Lost Lake, CA
    You can tell by the anemic Rod Beam thickness/width that that isn't a BBF Rod.
    Thank God, cause if it was in Mudpumper's engine it would NEVER hold up to that 'custom' 300 shot he's running.
    Not to change the subject, but I was out talking boats yesterday and heard that an 18' Performance Gullwing eclipsed 000's speed mark at Ming. Ran 8.50 @ 121. Not too bad with a 'BS' pump setup.
    Congrats to those involved in doing that.
    Just sayin'
    RR
