Jacuzzi Jet
Results 1 to 12 of 12
Jacuzzi Jet
    Senior Member Swain's Avatar
    Aug 2009
    Default Jacuzzi Jet
    I bought a boat with a Jacuzzi Jet has diverter, question is do they make droop snouts for them? Also how do I tell what kind of bowl it has? New to Jet Boats.
ID:	59830   Click image for larger version.
ID:	59831   Click image for larger version.
    Senior Member Hustler's Avatar
    Tujunga,ca
    post a pic of it and I'm sure you'll get more responces
    Welcome , Theres several possibilties to consider if you have a YJ or WJ it could have an "energizer" kit and thus have A Place diverter or Turbine trim , If you have an original YJ i could have a limited production Jacuzzzi trim unit You may also simply have a WJ with an early or late Place diverter A photo would be very helpful as said earlier Tom
    ps Droops are available only to the WJ and tyhen with an Adaptor ring
    Aug 2009
    I will get some pics up tomorrow thanks for the info. I know it has a Wedge in it not sure what degree.
    The Wedge can only go in a 12wj right?
    Quote Originally Posted by Swain View Post
    If it has a wedge it is most likely a WJ (unless its been "energized" ) Its still tough to say what diverter it is with out a pic Tom
    Aug 2009
    pics
    pics
    PICS?
    Aug 2009
    PICS?
    From those pics I posted up can you tell what Jaccuzi model it is?
    it is a wj, i believe that tom makes an adapter for it that will allow you to run a conventional droop. i'm sure he will wake up and post up soon.
    Tujunga,ca
    that is a WJ
    Aug 2009
    Thanks for the help guys.
    as said its an (unconverted) WJ (not energized) with a very early WJ Place diverter. If you were to use one of our Billet adaptors , to install a droop snoot or straight snoot , you would also need to "upgrade" the Place diverter trim as the early WJ/PD's were Jacuzzi specific (where they fit into the nozzle adaptor)
    Tom
