referbishing seats
Results 1 to 14 of 28
referbishing seats
    Nov 2009
    Langley, B.C. Canada
    Default referbishing seats
    Any body know of any good sites with tips and hints on refurbishing apostry do's and don’ts? I kind of what to try it my self so any good info is good thanks
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Quote Originally Posted by lefty's pride View Post
    post what you have for upolsetery
    [/SIGPIC]
    Nov 2009
    well it is just red and white vynal i think thin foam base to get the diamonds with foam cusions and ply wood bases. im going to use the old seats as a template for the new ones but im just looking for help full hint, tips, or reading on the net. i dont really know what to say.
    if you're going to go with the same thing you might want to try this
    http://www.copycatcovers.com/process.html
    pull off the vinyl and send it to them, they copy it and return it.
    you do most of the work and save $$
    I'm getting a quote on my stuff
    #55
    One of the simplest and popular way (assuming the underlying wood is damged) is to replace what you have with a pair of Fiberglass buckets and rear bench The Glass units are easy to cover , the backs can be painted to match the boat and the covers snap out for storage Tom
    Southwest corner AR
    X2 what Tom said and you will almost spend as much on supplys plywood, fiberglass,foam,etc.to build your own! My .02 WT
    WT
    WFL Crew!!!
    Nov 2009
    well im not changing buckets or bench all is good in this case, i cannot change change the look of the boat it needs to stay as it was in 79 other that seat color (that was ugly), and to the sending them out i am entertaing that idea but im really trying to say that i restored the entire thing,or as much as i can in my shop. it's kinda my tribute to my grandfather who's name is on the boat
    Ukiah,Ca
    you neeed to post a pic of the interiro and we can tell you how to build it . I have made my buckets and also deck lid and it turned out bitchen
    i used 3/4 marine grade plywood , datto'ed the joints , glue, and stainless screwed the whole thing together . I would also recomend a lil fiberglass in the high stress areas . seal the whole thing with resin
    [/SIGPIC]
    Nov 2009
    ok i'll get a pick of the seats so you can see. all the structure of the seats are in good condition i just need to freshen up the surface the white is not bad but all the red needs to be done for sure.
    Olympia, Washington
    If the woods in good shape just carefully remove the old vinyl and use as a template for your new vinyl. The only other tip I have is to find someone with a industrial sewing machine, sure makes sewing alot easier and you won't break needles. As with all this crap take your time and it will turn out great. By the way cool tribute to your grandfather.
    Junior Mumbler
    Dont try and "save" the white or any vinyl. It will only look as good as the worst piece. Make sure you use a good MARINE vinyl. If you want the same look but cleaned up a little I would keep the color pattern just dont top stitch "Diamond Tuck" the white. Make it smooth with a little pleat aruond the radius. Build the frames yourself, just copy the old ones. If those front seats are bent radius thin plywood dont do that again. Don't spend the$ on Marine grade ply. Not needed. Use good furniture grade foam. Its not that hard til you get to the sewing!
    Nov 2009
    That’s cool the seat backs are solid, you don't like the diamond stitch I loved it but ill take in to consideration the seat are flat bases and the backs don’t seem to get to dirty are you saying stay away from them because there harder to keep clean or is it to hard to get the lines straight. Are you able to get it done with a standard sewing machine? And is there a special type of thread to be used? I found a company to buy the fabric from aqua vinyl sales. But I have not found a place to get the foam not that I looked yet. The only thing other then the diamonds that Im worried about is the arm rests. The fabric goes around a very sharp bend to do the armrest. There is no padding around this area, and the fabric tore I don’t know if they used foam there before, I think Im going to need to use something harder like roll bar foam. Thanks for your input
    Surprise, AZ
    A standard sewing machine will hate you and make it a PIA. As for the top stitching, every stitch you put in the top will let water penetrate through into the foam and wood bases. If you like the look it's fine but keeping it all straight is another PIA. I would suggest drain holes in the bases to let the water out.
    Resin the entire bases good and the type of wood isn't a real concern. IMHO
    As for the padding at the arm rest, usually how it was originally done is, the foam at the sides was 1" or so higher than the frames. As you stretch the vinyl over it, it pulls the foam over the frames in that area. I ran an additional 1 1/2" strip over mine in that area. Eventually the foam will break down...
    Roll bar padding I would say not a good idea. Use a denser foam in the areas you want to be stiffer. I think foam densities are rating on something like the amount of weight required to compress a 12"x12"x3" piece of foam to a thickness of 1". Or something like that, don't quote me on that.
    I bought my foam from some outfit in FL. Can't remember their name...
    FYI I received my quote today. $700 for my seats, they are sending out
    vinyl samples today
    #55
