newb ? bout fuel tanks
Results 1 to 14 of 27
    Maple Ridge B.C. Canada
    Default newb ? bout fuel tanks
    the guy I bought my boat from told me that when 1 saddle tank ran empty ,I had to turn off the one valve & open the other ,witch are on the inside of the transum"don't burn yourself ha ha ".The local parts store explained that to do this electronicly would not be easy cause solinoids & gas isn't a good idea.....so my question . 1st why can't I just run the 2 tanks at the same time ,as 1,both valves open?there's only 1 gauge,don't know where the sending unit is or how it can monitor 2 tanks. 2nd if I can't ,how do u other guys control your saddle tanks?
    thanks for helpin out a newbee
    Yucaipa, California
    I run both mine wide open with no problems..mine hasa sender in both tanks with a switch to switch hot wires for the guage.
    1992 Eliminator Daytona 21'
    MPR FAB southwind011's Avatar
    riverside ca
    i run both tanks to a T fitting and i works just fine. their is a fuel selector Valve that you can install
    Yep. A two way switch on the dash and a electric switching valve.
    Surprise, AZ
    I run both tanks at the same time also. Never any problems... Both tanks into a water seperating fuel filter with one line out... Works fine.
    cool! come spring I'll open both valves & not worry about it can you tell me the brand & part # of a water seperating filter? thanks again
    Just my OP I isolate them with manual or electric valving and run the drivers side down (not out) then run on the opposite Although I respect the dual feed idea Its hard to get both tanks to "feed" at the same exact rate
    Surprise, AZ
    I made sure both lines coming from the tanks to the seperator were the same length. Although probably true, they don't drain at the exact same rate, I've never had an issue with them. Worst case was one tank had about one gallon more than the other after all day cruising around...
    Wouldn't hurt to have the valves so you could isolate them if needed... I would run them both open untill I needed to close one... Just to be different...lol
    I think my seperator is a Sierra 18-7775-1
    Redding, CA
    I run both to a "T" also, then one line to a separator.
    Like Tom said above though, they don't feed even. One of my tanks is a top outlet, the other is a bottom outlet. I have a petcock on the faster, bottom outlet tank that I "pinch" down to even them out a little.
    When I get just a few inches left in that tank I shut it in for reserve!
    (Started doing that after running out of gas one day)
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Senior Member sleekvino's Avatar
    just make sure your fuel lines are the same size in length, i have both tanks feeding at the same time works great.
    PORNO RACING INC WHERE ITS "HARD" TO WIN
    LaGrange GA
    On my boat the side of the boat that has the least weight on it drains faster as it's higher. I really only notice it when I have three people in the boat and the back seat passenger picks a side and stays there.
    If I ever run one of the tanks dry the boat will quit as it's easier to try and pull air than it is to pull gasoline.
    When that happens I have to flip my selector to the tank that still has fuel and get it to reprime.
    i agree with the others as that you can simply "hook" the tanks together, but to give you a choice, imco makes an electric switching valve that is coast guard approved, somewhat pricey, and i believe that rex marine carries them just to give you a choice.
    If you plumb both tanks to a tee low[like below drive shaft] then to your water separator, then to fuel pump. They will feed equally as each tank will naturally find it level with the other tank. My friend even pours gas in one tank only when adding 10 gallons and it flows to the other tank!
    I'll agree that under perfect circumstances , two equal tanks with equal lines equal retrictions (or lack thereof) and equally venting caps or vents will likely drain at the same rate However I prefer to eliminate the uncertainty that in an by an isolating vavle . Several times over the years we have adresseed compliants of "sputtering" , die out and drivability issues that seem to respond to isolating the tanks side to side just my OP
