jetaway oil reservoirs
Results 1 to 14 of 85
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default jetaway oil reservoirs
    I'm trying to find a oil reservoir on McMaster-Carr and i've found the page with them. The old threads i've found about this guys talk about theirs being glass. The ones i'm finding are plastic and have a max temp of 160F. They have a high temp version with will go to 225F but it's not glass and they dont have a 1/8 NPT thread type. Anybody know where i can get one?
    [email protected] is out of them....
    Olympia, Washington
    Have you tried Duane at HTP?
    San Clemente, Ca
    Quote Originally Posted by Oldelmn8tr View Post
    I would, but i need it by friday and he's too far. I ordered 1169K19 from mcmaster-carr just a few moments ago after talking with jack again. previous posts about these all talked about them being glass but jack said they are plastic... least the new ones are i guess.
    Not what sucks is i have to pull my pump apart so i can drill and tap the zerk hole to accept a 1/8 NPT.
    Olympia, Washington
    Goin racin?
    California
    This is what i got for mine #1303K11, its just like the old dominator one
    http://www.mcmaster.com/#catalog/115/2147/=4k9y9y
    okie, lake Texoma
    I never ran one and never had a problem with it, but when I had the boat down over last winter I talked myself into putting one on and the POS leaked everytime I'd make a pass. It would leak out of the weep hole on top of it.And Yes I had it tapped into the top of the oil cavity.
    Got tired of fighting with it and plugged it. No more leak.
    If you run the recommended HTP lube in the jet away, its designed to not expand very much as it heats up and wont cause internal pressure and leakage. The only reason I can see to run one of these resevoirs is if your trying to use synthetic gear oil or something that expands.
    San Clemente, Ca
    Goin racin?
    I wish, trying to get the jetaway back in the boat this weekend. Heading to the river for thanksgiving and plan on doing a bunch of testing if possible.
    San Diego, CA
    Put one on. I have one on each boat. Lots of hours on each. Never had one leak or overflow. You must start with a very clean jet away and bearing. If you have any grease leftover in the bearing you will have problems.
    Boat 405.
    okie, lake Texoma
    Mine never had grease in it. Everything brand new. Hole drilled at 12 O'clock straight into the oil cavity , everything perfectly clean, yet everytime I'd make a really hard pass itd fill the little resivoir full enough to spit out of the little hole on the top.
    I did take the spring & diaphram out of it as I was told to do, are you supposed to leave it in ?
    San Clemente, Ca
    What size reservoir did you have, [email protected] told me to get at least a 4-5 OZ version. I havnt gotten mine yet but the one that shows on mcmaster-carr doesnt have a spring/plunger in the picture. Maybe you had the one used for grease that some guys without the jetaway use?
    I was told that for drag use you dont have to have a reservoir but i will probably see a small leak after a pass. But for river use where your running the boat for long periods it was a must. I noticed the jetaway gets very hot.
    I had asked Duane about them, and if i remember correctly he recommended one for river use too (duane correct me if i'm wrong).
    San Diego, CA
    How many Oz. container are you using? How large of hole did you drill into the bearing cavity? I would drill like a 1/8" hole all the way through and then a Q size drill only part way through to be able to tap the hole with a 1/8" npt bottoming pipe thread tap. That way you don't have a huge hole all the way through into the bearing cavity. If you didn't do it this way I that is why when you make a pass it fills up I'm betting.
    So when you added the jetaway, you replaced the main bearing in the jet drive too, or at least took it off the shaft and put it through the parts washer. I've heard several people having problems of just bolting on the jetaway without first cleaning the grease from the bearing.
    The 5 oz version is perfect. How are you filling yours? do you fill it from the reservoir or through the fill hole and open the side hole for level checking?
    Here is a pic of the res.
    It holds 5 oz.
    Boat 405.
    San Clemente, Ca
    I'm confused, the one i bought is setup for a 1/8" NPT hole. Drilling a 1/8" hole would mean you couldnt TAP it for 1/8", are you running a larger thread size on your resevoir?
    Senior Member tahitijet's Avatar
    1/8 drill and 1/8npt are not the same size.. 1/8 npt is much larger then an 1/8 drill size.
    I never knew about NOT having grease in the bearing. Now I see why MINE leaks all the time Looks like I just learned something new today. I will be installing a reservoir this winter when I tighten up the pump.
    G H E T T O F O E L I F E
