Berkley rebuild
Results 1 to 14 of 15
Berkley rebuild
    Junior Member 81sunkisst's Avatar
    Aug 2009
    Arkansas
    Default Berkley rebuild
    Fixin to rebuild my Berkley JB pump. wondering if i should spend the money on a stainless steel impeller. I dont race make about 500 hp, just want something so i dont have to rebuild it again next season.
    i've got 1 for sale and i'm close 600 for a like new american turbine stainless aa cut what pump is in that boat? 12s dominator?
    Aug 2009
    Arkansas
    Its got a Berkley 12-JB-A. dont think i got enough motor for a AA impeller, thanks anyway though.
    Most OEM impellers are rated at around 400 to 450 hp , After market aluminums to right at 500 , Your probably a candidate for a Bronze or Stainless if you can see it in your budjet , Tom
    Aug 2009
    Arkansas
    Never heard of a bronze impeller, but i want it to last an got plans on puttin aluminum heads on it this winter. Which would up my hp. a little
    Nov 2009
    Langley, B.C. Canada
    in the first post it says you want to make 500hp what rpm you want to run 4700? if so why run on the edge when you can get a known good product
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    pm sent
    Angier, NC
    Thumbs up mag bronze
    mag bronze start big on cut and work your way down i would go with a aggressor impeller just remember the flow rate of a aggressor is more than a berkeley so your charts will differ from cut to cut
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Quote Originally Posted by 81sunkisst View Post
    on the bronze or stainless most all are cast to the largest size and then cut to the application. the aa that impatient has could be easily adapted to your situation, and agreeing with pro mod get a larger one and cut to your use, i always state it is a lot easier to make them smaller that to cut them bigger, if you get one to small you will have to buy another, go large then cut
    Quote Originally Posted by johnray069 View Post
    we went too small to begin with, now we're heading towards a aaa mag bronze aggressor
    Nov 2009
    where would you send it to get re cut? do local shops do that or is it a send out to mfg.? what engine specs are you sending with it to get it re cut?
    Angier, NC
    Default j069
    Quote Originally Posted by lefty's pride View Post
    johnray069 does all my cutting he is Big A Performance
    give him a shout awesome guy and awesome work
    14237458347
    athens Tn
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    Angier, NC
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    Quote Originally Posted by Pro Mod View Post
    yepppp the motor made more power than expected, and that's a gooodddd thing
