Aggressor aluminum impeller HP
Results 1 to 14 of 36
    Senior Member Amango's Avatar
    Sep 2009
    Default Aggressor aluminum impeller HP
    I would love to spend the money and buy a stainless. Not in the budget. I have been running 650 HP on an aluminum aftermarket aggressor impeller b-cut. Now i will be putting the N2O to here 225 shot. Is there anyone out there that has been running 850+ HP on an aluminum impeller. I now that when the boat unloads and loads again that's when the like to go Bang.
    Just my .02, but an impeller is alot cheaper than sinking a boat. Not worth the risk IMO.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    I am in no way a pro at this im sure someone will chime in here in a few, but I hear that an aluminum should only be used up to 600Hp, I have seen one flex and crack with less that 500hp, unloading out at Elsinore on a sunny summer morning! spend the money now or later, your gonna spend the money, Buy used! im sure someone has what you want used! what about Mag Bronz? there is a less spendy resolve!
    Find it unlikley you would put that much power and a NOS shot to a set of Cast pistons Why would you short your self on the Powertrain by using an aluminum impeller rated for 5oo hp ? food for thought just askin'
    Sep 2009
    More i think about it i will install a stainless thanks for knocking some sense into me about this one the time and money put into the engine. Not worth losing the boat or getting heart doing it. I'm locking for a good A/T B cut stainless impeller preferably an aggressor if anyone has a good used one i would be very interested. I did install the heavy duty drive shaft on the pump when i rebuilt it just ran out of money for the stainless. Thanks
    Newton Ks.
    Quote Originally Posted by Amango View Post
    Save half your Stainless money and buy an Aggressor mag Bronze, same nearly unlimited power rating, just don't feed it rocks.
    H.L. Mencken
    San Diego, CA
    IMO, i'd stay with the stainless. You can't repair a Mag/bronze impeller. Definitely buy one used. I've seen several in the spam section for 500 and less.
    Boat 405.
    mag is repairable same as stainless...
    Feb 2009
    What do you weld that Mag/Brz with?
    Circ
    San Diego, CA
    Really? If so I stand corrected, but I understood that they were not.
    Boat 405.
    Quote Originally Posted by Circular View Post
    Circ
    All weld shops sell a Rod for Mag Bronze.... Just tell them the Alloy.
    Sep 2009
    Do the American turbine stainless impeller's have the wear ring on the back of the impeller. Hope that's not confusing but the Berk's are flush and A/T have the lip to seal in the bowl. I found an stainless Berk for sale but would really like to keep the lip that seals in the bowl like my current impeller has any thoughts. Thanks and Happy Thanks giving
    San Diego, CA
    Not a big deal, alot of guys run stuffer plates and machine off that lip on the impeller. I'd be interested to see a comparison between a pump with a stuffer plate set up vs. one like you have mentioned.
    Boat 405.
    Feb 2009
    Happy Turkey Day Pops. What is the alloy number for your mag/brz so that a welder could research the proper technique for that alloy. Thanks.
    Circ
