impeller-help
Results 1 to 14 of 39
impeller-help
    Aug 2009
    Unhappy impeller-help
    hi, im jens from good old germany and i think i need some help with my impeller because my boat dont have a good hole shot
    engine is a 327sbc with mid tuning about 300hp
    the jet, berkeley12JAB with droop and diverter
    boat: 21ft glastron style
    please look at the pics
    greetings jens
    p.s.sorry about my english
ID:	60574 Click image for larger version.
ID:	60575 Click image for larger version.
ID:	60576 Click image for larger version.
    Jens thats sort of a big boat for a "B" impeller, what are you spinning it to rpm wise?
    Aug 2009
    at the start about 4600 to 4800rpm but i have problems with my ignition
    i think 5500 to 6000 rpm could be possible
    we used that motor in a minipuller at tractor pulling and there he turns up to 7500rpms
    speed is about 45miles at 4400rpm
    jens
    so once it quits cavitating, your running 4400 rpm's when up and running.
    Aug 2009
    where would you start to quit?
    ride plate, loader grate, pre loader???
    jens
    member
    Nov 2008
    Jens, take your hand hole cover off and measure the clearance between your impellor and wear ring. I see you have the imp nut off, do you have a imp puller? SJ
    Aug 2009
    the clearance is about 0,25
    we fixed it already....
    ist it possible to indentify the impeller?
    jens
ID:	60580 Click image for larger version.
    Jens first Welcome to PB ! Reading your post several things come to mind not the least of which is the "droop" ? assuming this was correct typically on a boat this large this IMO would be a hinderance rather than a help , The trim is a real plus and I would be interesting to know exactly what impeller is currently in the jet also sounds like your motor may be built to make power at high rpms what about it? Cam , compression etc , just some random thoughts here Tom
    edit .. BTW your Impeller appears to be an A unless my eyes decieve me ...
    Aug 2009
    hi tom
    cam: compcams part nr.12-210-2 grind cs268h-10
    intake: torker 2
    carb : edelbrock 600 marine
    compression: just can say that they are all the same
    jens
    Monroe, WA
    With a 300 hp motor I'd say you're going as fast as you're going to. How fast do you want (or need) to go.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Aug 2009
    hi malcolm
    just a few more miles
    my problem is the hole shot, feels like slipping wheels
    jens
    Senior Member pilot940's Avatar
    Chandler, AZ
    Quote Originally Posted by Jens View Post
    hi malcolm
    jens
    Not too sure, but it sounds like a job for an inducer impeller??????
    Morgan Hill
    hi malcolm
    jens
    jens,
    Just switch over to km/h, you will be putting up some big numbers.
    By the way, don't apologize for your english, you are doing better than most around here
    I would say with you're combo., the motor is lugged down too hard, if it has turned into the 7's before. I'm going out on a limb and thinking the tune is where the issue is, at 300 hp, you should be able to turn that "B" at just over 5,000 PRM, but the small plant doesn't have the torque to get there.
    I can't even imagine you have access to a dyno, or maybe a BC impeller?
    A big boat and a B impeller are horrible combos, not enough volume to get things rollin'.
    GT
    GT
    Aug 2009
    Quote Originally Posted by pilot940 View Post
    i think so too
    i combination with loader grate?
    jens
