SKi Tow Help
Results 1 to 14 of 14
SKi Tow Help
    Alamogordo NM
    Default SKi Tow Help
    The Ski tow i have seems to be intended for stock/ low rise intakes. I have been using it by using 3'' bolts into the heads, and a nut to secure the intake. The bolts have started to bend, and yes, I used grade 8. Is there such an animal as a ski tow for an olds that will work with a torker intake?
    See if you can find one that just 4 bolts to the back of the engine, the old's have enough issues with the intake already.
    Nov 2009
    Langley, B.C. Canada
    Agree with that you dont want to get a big old boy like my uncle behind that pulling off three bolts and off the intake. i seen mine bend with all four bolts off the block. your just lucky your driving and not watching how much bend there really is there pulling 200+ lbs out of the water
    Alamogordo NM
    Quote Originally Posted by lefty's pride View Post
    I have been driving, but I have also been the guy in the water, I am the heaviest person I usually tow (215 lbs), I can imagine the thing snapping while I am in a hard cut and it flys back and whacks me right in the head!
    Alamogordo NM
    Do you mean it only attatches to the flywheel cover bolts? sounds good, maybe the guys on "bethel brothers hotrod" still have the one on their boat.
    The Earth
    Blog Entries
    24
    Quote Originally Posted by 74glencoe View Post
    We make one specifically for the Torker. That's the good news. The bad news is I am out of stock and with business the way it is (poor) probably won't be running any until Feb-March. We need to run 25-50 at a shot to make it worthwhile.
    While that's no immediate help, if you don't need till spring it could be your answer. Our torker tow mounts 2 on the intake and 2 on the bellhousing.
    Mike
    Alamogordo NM
    Mike
    Awesome! I wont need it till then, I will get in contact if I cant to find one that bolts to the bell housing, Hopefully it is tall enough to keep the rope off the headers.
    The Earth
    Blog Entries
    24
    Depending on the boat, if you find one that fits the bellhousing make sure it won't hit the transom. Seen that scenario before.
    Alamogordo NM
    Default Thanks
    Thanks Rexone, read and noted, I think most will clear.
    Chance , risk life and limb in the pallet racks for this bad boy hope its what your lookin for ? Tom
    ps the one in the background is a rare piece (with ski racks) says patent "Kona" boats
    Alamogordo NM
    Not seeing a pic Tom, and dont lie, I know you sent Josh up there to get it. Tell Rhonda thanks for dealing with a Redneck on the phone.
    Dopey me forgot the pic
    Alamogordo NM
    Thats the one, ship away.
    Alamogordo NM
    Default Cleaned er up
    I did quite a bit of cleaning it up. It looks awesome, 99% of the rust is gone. Used 1000 grit, then my polishing kit. I am gong to try the photobucket route this time, tell me if they show up allright.
    [/QUOTE] As sent
    [/QUOTE]
    Front after polishing
    Back after polishing
    Mounted
