Daul carb setups pics
Results 1 to 14 of 68
    Senior Member Boost's Avatar
    Pomona ca
    Default Daul carb setups pics
    Looking for some ideas on pluming a set of daul cabs sideway mounted,will a 2 port regulator work fine or will a 4 port be better? here's what I'll be running 2 750 Quickfuel post some pics Thanks BOOST
    Colfax, Ca
    here one of mine :
    Denton, TX
    Kinda hard to see..
    Silverdale, Washington
    Here's my setup. Twin QF regulators on a log each feeding 850's
    Lurker
    NC
    Default My old set-up
    A single 4 port regulator (of good quality!!) is the cleanest and easiest way to do it.
    This will easily support 1000hp with the proper fuel pump.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    A little copy paste
    Info Jr's jet boat. We have 2 alcohol carbs and a Ron's Gold belt drive pump. #10 to a BG Y block #8 to the carb fuel lines and this bypass valve out of the top of the Y block. Enderle linkage
    Some might say those #6 hard lines are too smalll for alcohol and the "T's" are restrictive and the fuel bowls do not hold enough or thats too much pressure. But idle pressure is 7 or 8 lbs and when the carbs are flowing fuel the pressure is 12 - 15 lbs. Since the float needle seats are open anyway pressure is not too high and feeds it plenty.
    Senior Member brgrcru's Avatar
    Montrose
    Not to jack the thread. But you have done a great job with this boat. Looks great. Did I miss the final build thread on this?
    Quote Originally Posted by brgrcru View Post
    Thanks very much. It was a great project and I learned a ton. All in all I'm really happy with the outcome but have yet to leg it out as I've been struggling with setup issues. It's got a severe case of hop-skip-and jump. Tommy and Josh at JetBoatPerformance have been giving me some ideas so I can try to settle it down a bit.
    Thanks again.......john
    San Diego, CA
    prior setup on the 405
    current setup
    Boat 405.
    Nov 2008
    Fuquay-Varina, NC
    Senior Member Rivereliminator's Avatar
    So Cal
    Default Linkage
    Here's mine...
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Mine.
    Senior Member sturat's Avatar
    Houston TX
    Four port reg and a single line to each bowl is the cleanest and cheapest way to go about it. I use a 4 port and 4 straight#6 done deal easy as it gets
    Legalize the Constitution!
