What's the fastest v-hull ??
Results 1 to 14 of 32
    Co-Founder of SHB MarKist's Avatar
    Default What's the fastest v-hull ??
    I have a 18' Sunkisst , lite lay-up , what would be the fastest and safest speed for this hull, I'm gonna spray the chit out of it next year ! but I want to keep it safe as much as possible, what do you guys think ?? thanks
    Markist
    "Life is SO much better now......
    i'm back!! 1QuickCP's Avatar
    Montana
    Well I had a beismeyer true v hull 19', blown(C-16 and 24 psi,500 inch) with a 200 shot..got it to run 101 at parker steady as a rock..ran about 92 at altitude with less spray.
    Friend had a 18' kachina, 500,TR, spray, ran about 86 stable as well,put same motor in a 18' CP..bam 98.
    ur gunna have to keep the pump loaded, and that means dropping the shoe, and that gets risky if u have to shut off quick. I would for sure put a pressure guage on the pump intake side and keep her loaded but not to excess. Most all v-bottoms need a good amount of shoe, my beismier ran 1/4 inch under keel to keep hooked up on the bottle, the kachina 3/16 inch...IMHO
    Angier, NC
    Quote Originally Posted by MarKist View Post
    Markist
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    High Rock Lake, N.C.
    Markist
    FAST and SAFE in the same sentence........You better worry about blacking out when Momma wraps you up side da head
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Lightbulb spraying the shit outta it?
    Markist
    how does it handle now?
    what speeds are you running now?
    when you say spray the shit outta it what do you mean?200500
    lots of things to consider when you say you are going to spray it.
    19' Rogers Bonneville TR, heavy boat, went 115 and change with 1000+hp blown motor. ran low 9s in the quarter too.
    Lurker
    NC
    I THINK WE NEED TO WORRY ABOUT SANDING BEFORE SPRAYING!!!!!
    Montana
    Yeah the rodgers really run great !!! remember one at parker njba, I think called "tacky bitch" but my memory sucks....
    Quote Originally Posted by 1QuickCP View Post
    that is Don Jone's boat. He still has it. I believe he said he went 116 in it.
    What's this "WE" chit ???
    Markist
    Senior Member eliminator's Avatar
    Roanoke VA
    Spider Monkey Racing
    FRIENDS DONT LET FRIENDS DRIVE EGGBEATERS
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Not to worry Mark, Gina's gonna whoop up on yer ass as soon as you whack the pedal anyway, may as well just jeave it alone! Save some money too!
    Or buy a Tunnel and she will be too stoked about the ride to worry about the speed!
    B1 Racing cs19's Avatar
    I agree with Cyclone. Rogers. 18' Gullwing 2nd choice.
    B1Racing.net
