Vaccuum advance
Vaccuum advance
    Aug 2009
    Fox Valley Wisconsin
    Default Vaccuum advance
    My old dizzy went south. Can I use a hei with vaccuum advance on my bbc 454. what are the pros and cons.
    Morgan Hill
    Quote Originally Posted by BAJA JA View Post
    Yes, I would lock out the vacuum pot...It can be removed and locked with a simple piece of aluminum, marine engines are under too large of load for the vacuum advance to work...
    If you have an enclosed engine compartment, I would discourage it totally....
    GT
    GT
    Not likely safe and /or "Marine approved" and as Glenn said the Vac advance is of no real use ,However in a Jet boat application , if you do decide to use it/one you'll have to modify it to give a greater total centrifical advance or run quite lot of initial to get mid 30 "ish" total Tom
    Dallas, TX
    I completely removed mine and locked it out with a screw. I also added a curve kit and the lightest springs.
