Low Pro Intake?
Page 1 of 10 1 2 3 4 ... LastLast
Results 1 to 14 of 135
Low Pro Intake?
    Southwest corner AR
    Default Low Pro Intake?
    I will be rigging a TX 19 in a few weeks and had this on my mind! What setup differences do you incounter with the low profile intakes? Motor plates,rail kits, etc.? And would it add performance by just adding a low profile intake? WT
    WT
    WFL Crew!!!
    lots of variables ,What intake are you considering and are you going back in the same relative position as the current ? do you already have a rail kit and what drive line (length) etc Tom
    Southwest corner AR
    Tom, I was thinking of stock location and the rail kit I got from you and all the other rigging! Drive line will be a Jet-a-way with a standard 1350. I think that the rail kit is Lightning! On intake whatever would work best maybe MPD or? WT (AKA Coby)
    WT
    WFL Crew!!!
    mpd
    If your are going to bed the intake casting in the same cut out, the jet it self will be approximatley 2" further forward. Running a jet-away and a 1350 you most likeley wont encounter any pan depth issues as the engine will be far enough forward to clear the intake. and your rails will "adapt" Tom
    heres some info from Jacks site : http://home.pacbell.net/jmcclure/LoProIntake.html
    need to keep it set-back coby, call ervin and talk to him about setting the intake for ya.you get too much weight too far forward in that gullwing and its gonna handle ill.
    Breathing Diesel Shotgun19's Avatar
    Michigan
    Need to set it back
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Thumbs up way far back!!!high pro intake
    my vote is tostick it as far out of the boat as possible,set it so the handhole cover is atleast 12 inches back from the transom and hey put 2 bowl spacers and longest droop they make
    or you could talk to someone that knows what they are doing and has been around for awhile
    but i really do like my ideagood luck cobyTravis
    scott/ervin, it don't matter which 1 as they're both schooled well in low pros, i'd let them do it before tacklin in myself i've set a couple intakes and its no fun
    lake Ouachita AR
    you didnt like my ideai bet it would work great
    yes they are both very well schooled in the process,as alot of others.
    i was mainly jackin with coby
    Feb 2009
    Default Low Pro
    If you want a low profile intake with a history of success go with the PPP.
    Since you are in the AR area call Erv Capps. He has some very fast boats and a ton of experience with the intakes and the pop-offs.
    If you need I can get you his number.
    you didnt like my ideahandi bet it would work great
    not the ideal way of doin it
    ervin put hass's meirsh low pro intake in and did an awesome job he picked up alot of performance
    lake Ouachita AR
    Lightbulb advantage??low vs reg.
    might i ask the overall advantages of these low pro intakes
    i dont really know cobys overall goal of this build(mph,e.t.ect.)
    but say i was buildin my Tx.
    i for one dont care to go 100 plus in a gullwing style boat,say i want 100mph and that is plenty fast for me.guys have been doing this with ease for along time with standard intakes.
    so what would a average guy gain from the intake,when i say average the regular run of the mill lake feller
    i think this could be a good discussion for non-race to full race boats.Travis
    B1 Racing cs19's Avatar
    there is a spam section here ya know.
    just sayin.
