Best Weight Oil to run
Results 1 to 10 of 10
    Senior Member Swain's Avatar
    Aug 2009
    Default Best Weight Oil to run
    I have a BBC, not much done to the engine, just solid lifter, decent Cam. My boat starts up and pressure is 50lbs I think its a low volume oil pump, but drops soon as the oil heats up to 15-20, but then after sitting for a few mins goes back up could the oil pump be bad or could it be bearings? I am going to pull the motor over the Christmas Break. The oil had some water in it but I drained the oil twice to clear it up. I am currently running straight 30 weight.
    Jason
    Quote Originally Posted by Swain View Post
    Jason
    Jason the general rule is 10psi for 1000 rpms eg 40 @ 4000 however most modern engine will maitain at least 25 psi at idle Assuming you guage is correct (verify with a "know good manual") I'd be concerned might be time to inspect some lower end bearings Tom
    Bakersfield
    I run Valvoline VR1 50WT. It's what I like. I run 75-90 PSI cold idle and 65-75 warmed up and running down the river.
    Just so you know, the correct weight oil is, and always has been a
    Nov 2009
    Quote Originally Posted by Luckie Stiff View Post
    Senior Member wildstreak's Avatar
    Feb 2009
    East Texas
    I run valvoline racing 20/50. My opinion on your oil pressure is, you should flip it over and roll some bearings in and install a high vol pump. That should correct your oil pressure woes. Bearings are cheaper than crank, rods, pistons and a block. We can all agree on that!!!
    Newton Ks.
    Yea, there's already 20 threads (or more) on "which oil should I use", and everyone advises you run what they run.
    My engine makes 55+psi at idle when it's cold, 59psi flat-footed hot, just under 6,000rpm, for miles, 23psi hot, at idle, and this is just fine for an engine.
    I run 10w-50 synthetic, Castrol Syntech, have for 5 years now.
    H.L. Mencken
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Quote Originally Posted by wildstreak View Post
    Just from past experiance I would stay away from that HV pump
    How much oil do you think will end up in the heads after running down the lake or river turning some good rpm?
    I had oiling problems with a HV pump causing a lose of pressure at high rpm, so it got switched to a standard volume pump and everything worked great after that
    As far as oil is concerned that is a can of worms
    I use 15-50 mobil 1 not saying its the one for you just saying it works for me
    High Rock Lake, N.C.
    I would stay away from the High volume pump also turning that many RPM's. Pumps all the oil to the top and then all out the breathers.
    Aug 2009
    Quote Originally Posted by GasGuzzler View Post
    I noticed that also my breathers had oil coming out of them. I gotta check that out.
    Charlotte, NC.
    I switched to a high volume pump and dont have that issue........Any more . I had to get some tall breathers.. Before the tall breathers it was a MESS. then again im not turning the RPMS that a lot of you big dogs are with my rat motor so YMMV.
    However i will say there was a big fat warning on my high volume pump about how the PSI will drop at idle to below what a normal pump would reflect. So far it seems to be an accurate discription of how she acts.
