Hydrolic Diverter Pump ?
Results 1 to 14 of 31
    Bullhead City, AZ
    Default Hydrolic Diverter Pump ?
    Hydrolic Diverter Pump ? Who makes the fastest responding unit? Full up to full down. Who's pumps can handle 24volts?
    Jim
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Santa Clarita
    Parker
    have you tried ultradyne?
    Quote Originally Posted by Squirtin Thunder View Post
    Jim
    WHy not use Air?
    Senior Member CP598's Avatar
    Sep 2008
    WHy not use Air?
    Thats not a bad idea, do you have any more details? Like the pump, solenoids etc.?
    Thanks.
    TEN THIRTY ONE RCB19's Avatar
    Parker
    Yep.. Fuelinmyveins here on the boards switched over to one a couple years ago and it's a much better/quicker/reliable unit than the Bennet pumps.
    RCB
    B1 Racing cs19's Avatar
    Quote Originally Posted by RCB19 View Post
    And a total nightmare to wire up if you want to use anything nice as far as an up/down button. Done 2 of them.
    To make it "air" it needs to be either co2 or nitrogen, we run co2 systems at the river. I wouldnt do it on a lake or river boat, you will regret it.
    If using a CO/air system, you would need up / down position stops, because there is nothing to keep the nozzle from changing position, besides pressure.
    Just by using a power relay for the trim pump, and short as practical hyd lines, you would be suprized how quick a diverter can be
    Apr 2009
    SW Ohio
    Are there any affordable alternative pump/solenoid units? ideally a self contained 12v? I considered (still am) using an automotive power steering pump with an electronic solenoid. the solenoids are about $100 new, the pumps are cheap from junkyard or parts store. The rest is plumbing fittings/hoses/wiring/switches. http://www.northerntool.com/webapp/w...9569_200329569
    the only drawback is the power steering pump is soaking up a couple horsepower all the time. It may be possible to reduce the pressure or RPM so it soaks up less power. I doubt the diverter cylinder needs very much pressure or flow.
    i'd like to see someone use the water pressure coming from the jet pump. its andendless supply of h20 when the engine is running, even at idle.
    t-out of the inlet line to a pressure regulator with an overboard dump, use a 12-volt solenoid valve to control the water flow to either side of a stainless steel hydraulic cylinder. should work fine.
    why not?
    Spiral out MikeF's Avatar
    why not?
    Never thought of that.....sounds doable.
    Why would you need a quicker responding up/down than a Bennett?
    #55
