popoff question
Results 1 to 6 of 6
popoff question
    Default popoff question
    Somebody please enlighten me . Whats all the electronic gadgetry for?
    B1 Racing cs19's Avatar
    Thats a nelson valve. Its an electronic valve. All others are C02.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Whats the pressure guage for the intake pressure?
    Exclamation
    The guage is how you set the popoff to open at a certain pressure. The electronics is the Brain that makes the valve operate.
    Sooooo it has some type of solenoid inside .Moneysucker open it up so we can have a look
    Atlanta TX
    You can completely disassemble the valve to see how it works , it's very simple . You cant hurt it & it's good to lube it up with some WD-40 anyway. It has a huge soloinoid in it like out of a starter. You need to lube it at least a couple times a year IMO so the solinoid dont stick. At least I did but we get upper 20* weather here in the winter that may contribute to the sticking. Cant help on the pressure gauge part mine was disabled when I got it (i think). I only used it as a manual popoff. I do know the 3 large allen head screws at the base of the valve are how you adjust the pressure for the automatic side. If it was pre set previously , I wouldnt move those till I ran the boat a few times. Just my .2
