o2 sensors
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 45
o2 sensors
    Nov 2009
    Langley, B.C. Canada
    Default o2 sensors
    ok so i was entertaining the idea of going to fuel injection but i can't find any hard info of what exaust temp you need to run an o2, im running exaust logs, do they cool the exaust temp to far to run? can you run a air fuel ratio guage or is it to cool to run them either.
    most wideband air fuel meters use a heated element o2 sensor, there's a 12volt lil heater element inside them that heats up when they 1st turn on so that the sensor part of it starts working faster i wouldn't sweat egt's if you're gonna use a wideband,but too high a egt and the wideband will stop working period.
    get ya 1 of these, baddest wideband set-up i've found for the price
    wb2 wideband does alot more than just a wideband meter can and its nowhereeeee near the price of a racepack
    Quote Originally Posted by lefty's pride View Post
    1.) O2 sensors are not required for EFI.
    2.)Since your logs and risers are water-jacketed, you will have difficulty installing O2 sensors in them.
    3.)If you were planning to install them after the risers, you can't do that. Water is mixed with the exhaust at this point and that will kill the sensors.
    Nov 2009
    well i wasnt planning on putting it in the logs due to the water jackets and i wasnt planning on putting it in the water but there are these plug on the other side of the riseres i think there dry.
    Ada, Michigan
    It's true that an O2 sensor is not required to run EFI.
    You can run open loop right off the maps.
    However getting the maps right in the first place WILL require an O2 sensor.
    It will be very difficult if not impossible to get EFI tuned right without an O2 sensor.
    The best setup by far is running closed loop with the O2 sensor constantly correcting the A/F mixture to match the target A/F table.
    It is a reliable and proven setup in millions of passenger cars every day.
    I know several guys who installed an O2 sensor in their water jacketed exhaust and run closed loop EFI. Just make sure it's well ahead of where the water is dumping in. It works fine.
    California
    You could put a spacer between the riser and the log and install your sensor at that point
    Nov 2009
    well i think i have a spot already but what kind of temps am i going to see at the riser and what temp does it take to lite the o2 sensor i hear i need 600*f
    The side plugs on the risers go into the water jacket.
    Sacramento area
    Default Egt
    Thats a great idea Josh. I like that alot.
    Charlotte, NC.
    He might want to post a picture of where he is planning on putting this thing. I too thought that the plug he was talking about was in the water jacket.
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    What about tuning a carb w/ a wideband O2 hooked up
    with the water shutoff & then removing the sensor, plugging
    the hole & resume the water injection? How much would this
    change the tune? Otherwise, I didn't think any fuel injection
    would work w/ water injection running across the sensor?
    O 2 sensor has to be up stream, in the exhaust flow. Water gets mixed on the down side of the riser. A 2-4" spacer can be fabricated for an O 2 postion, between the log and riser.
    Nov 2009
    ya but im still asking what temp im going to see in the tube? i dont really want to be screwing around just to find out it is not hot enough to get sensor to work i need 600 for the sensor am i going to see that in the exaust flow?if any body knows that would be good. i know the out side wont get that hot but i am loosing a lot off heat to the water
