Carb Spacers
Results 1 to 9 of 9
Carb Spacers
    Team CJ460 Just Electric's Avatar
    granada hills
    Default Carb Spacers
    does anyone know if they make a half inch carb spacer or is the standard 1 inch.im too lazy to mill a 1 inch down and would rather just buy a half inch if they make one.my carbs with the throttle linkage set up i have wont aloww the accel pump to completly push down all the way unless i space it. the only one i could find was at summit but not for my app thanks
    MAMA TRIED BENSE's Avatar
    SOMEWHERE BETWEEN HEAVEN & HELL
    FILTHY FEW
    Default spacers
    Just grind or mill the manifold, you don't have to take off that much, thats what most people do. i'll look to see what spacers i have.
    Quote Originally Posted by Just Electric View Post
    There are pages of them on Summit,, 3.75" thick,, .500" thick,,, aluminum,, phenolic and plastic.
    granada hills
    found those thanks
    granada hills
    Quote Originally Posted by Jim Brock View Post
    not the problem jim. the plate/throttle bracket support wont let the accel pump push up cause it hits unless i space it about a half inch.got it figured out was just seeing what else was out therelike skinning a cat theres always more than one way
    Default spacers
    just give me a call!!!
    Charlotte, NC.
    Default Can i ask a dumb question
    Is the spacer only for allowing linkages the proper space or is there some other benefit?
    Nov 2009
    Langley, B.C. Canada
    you sould be able to even get extra thick carb gaskets, that what we use on the race car to get around the no spacer rule, i thnik there 1/2
