Pro comp heads??????
Results 1 to 14 of 35
    Default Pro comp heads??????
    Has anyone had any experience with pro comp aluminum heads? I am looking for a set of aluminum heads for a SBC. Just wanted to know a little info on them.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Helped a friend put a set on his 350 in his 67 camaro this summer
    Did not notice a major difference in performance, had to use a thread chaser on one of the intake bolt holes as it was not done very well
    I guess you get what you pay for
    save your money for some rhs heads, they're not that much difference in price but the quality is there with rhs. i've ran procomp heads and it took alotttt of work on the heads to get em right. sure they worked, but the time i spent on them i could've bought rhs.
    Your selling your sell way short if you try to run them out of the box. You may be will be surprised by the lack of QC in the product. Search the forums here, and the yellow bullet forum, there are some heated debates, and informative articles posted on the topic
    TEN THIRTY ONE RCB19's Avatar
    You get what you pay for in cylinder heads. The aluminum will save you some weight but you would be much better off finding a nice pair of production 990 heads and having them ported by someone who knows what they are doing if you are are on a budget. I think the Pro Comps are made in China...
    Edit.. Just noticed that you wanted the heads for a SBC. Never mind on the 990's then.
    RCB
    Quote Originally Posted by RCB19 View Post
    Not trying to thread jack, but if you're willing to spend the money to rebuild a set of iron heads, why not use the aluminum heads as your core's to build? They have bigger ports, flow more cfm, saves a ton of weight, and as others have posted in other threads they work better than production heads when properly built. Cost wise they aren't much more for new heads than buying used core heads. Just a thought.
    El Cajon, Ca.
    I've used the sbc and bbf heads and the best description of what I found is they are slightly better than stock... but you have to everything to them as the quality control is non existant. Guides will either be too tight or too loose (sometimes all in the same head)... valve job sucks monkey balls and you better cc them as the set of bbf's I got were 8cc different from each other and waaaaay bigger than they claimed them to be. But as in both cases... customer had busted stock heads, not a lot of dough, and willing to let me "try them out". With the same exact port work and all the parts from the busted heads and nothing done to the bottom end the ford heads picked up about 150-200 rpm from the best the motor ran with the d3ve heads. Not spectacular upgrade... but again... better than investing the same dough into a set of d3ve castings.
    Final analysis: if you got busted up stock stuff and looking for a cheap repacement or slight... very slight upgrade... then yeah, after reworking everything that is supposed to be done to a "bolt on" head (valve job, surface, guide work, threads, etc...) they will work fine. But if it was MY money being spent... I'd wait and save a coupe of hundred bucks more up, step up and buy a better quality head that would be a true upgrade.
    The Bostick®
    Trick Flow 557 BLUE OVAL CP's Avatar
    Lomita, CA
    Perfectly said. This was my exact experience with the BBF ProComps. In my case they were a disappointment.....
    I think you guys made up my mind. I knew they are to good to be true for the money. Gonna get a good set after the first of the year. Thanks
    Redding, CA
    Quote Originally Posted by ttshock View Post
    I think that is a good decision. I made that same decision a couple years ago, but for BBC. Debated for a couple months, but having worked in machine shops before, I knew what inexpensive castings usually lead to.
    I ended up getting Brodix BB 1 heads. Not as much as Darts or other heads the racers prefer, more than the Pro-Comp heads though. But was glad I waited.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    i will agree with that statement about the procomps being a better start than 990 cast heads. 80lbs less weight too boot, but its wintertime, no reason not to save up, buy da better heads.
    San Francisco Bay Area
    Thumbs down
    We call them "Pro Crap" heads because they are absolute SHT. At least the BBF heads are.
    High Flow Dynamics
    Cool
    NOT!
    I'll take well prepped D3VE's over well prepped ProCraps anyday. And please don't point to the weight savings by way of the ProCraps being aluminum; if you are looking for high performance aluminum heads for the 385 Series, then the ProCraps shouldn't even be on that list.
    LO
    High Flow Dynamics
    Pie Wagon Newbomb Turk's Avatar
    Dec 2009
    Midwest
    What are the thoughts on AFR's?
    "Does have a little wang in it...good though"
    Newbomb Turk...
