Wow...I guess I'm one stupid son of a.....
Results 1 to 14 of 40
    Default Wow...I guess I'm one stupid son of a.....
    First off let me say I'm sorry for another starter thread. I'm stumped. I don't know what this thing wants. I'm going to try to stick a vid or 2 up. I think I still have issues with the starter itself, but maybe I'm just too stupid to set it up right. Do you guys think these sparks are from a lack of engagement? It seems kinda weird to me that if I pull the pinion gear forward in to the ring gear by hand it just stays there. I can wiggle the pinion gear slightly clock wise and counter clockwise. So I don't think I'm too tight. I haven't got a clue what to even try at this point.
    Default one more
    Cas
    Cas is offline
    Angry American Cas's Avatar
    in the first vid, the gear appears to be engaged before you hit the switch. It then appears like the gear is not disengaging and the metal to metal is causing the sparks. Also, the gear should not be engaged in the flywheel before it has power to it.
    Dumb question but is your flywheel installed with the proper side out?
    In any case, that starter sure sounds to be struggling to turn the engine over....have you tried pulling the plugs and turning it over to see how it spins?
    2nd vid ends a smidge too soon
    Cantard 71hallett's Avatar
    snow bank
    Its not going in deep enough and I think that is why its kicking back at you. On backwards is worth about .030 - .060 not in your favour.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I see several issues.
    it's not spinning fast enough. Either battery power or starter going bad.
    And the starter gear and flywheel are not lined up properly.
    First video the starter gear is already engaged.
    I think there should be .060 clearance between the point of the starter gear and the valley of the flywheel gear when engaged.
    Where is the spring that returns the pinion gear?
    QE 439 Twin Turbo
    snow bank
    Tooth depth is prob a little tight and holding it....maybe?
    snow bank
    Put the can of gas and the matches down Kreg.
    New Port Richey, FL
    If you can pull the pinion gear out by hand theres one problem for sure.
    QE 439 Twin Turbo
    Senior Member bp298's Avatar
    LHC
    pull all the spark plugs and take another video.
    spacing between starter and ring gears look different from one vid to the next...
    I'll pull the plugs and shoot another vid I guess. I'm going to shoot the pinon on the starter with some black paint, to try to get a better idea of whats going on. Like I said I find it odd also that the pinion likes to stay stuck in the ring gear. I can pull it fwd by hand,have to twist it usually to get the teeth to line up...and it slips in freely,and stays there.
    snow bank
    Is there a spring in the solenoid or did someone forget to put it back in?
    460
    460 is offline
    ATTA BOY 460's Avatar
    That is what i was just going to say. There should be a spring that retracts the bendix. Weird
    Most of our chevy starters come with a little dowl .060 think to get the proper alignment between the flywheel and the bendix
    I could be wrong.....but a year or so ago, I remember asking the manuf. wtf is up with the gear sticking dealio. As I recall...they told me the motor starting was supposed to kick the gear back out . I'll call em monday, I have the # memorized.
    460
    460 is offline
    There is a spring in the starter with the bendix and solenoid that pushes out and retracs the bendix. The bendix shouldnt be touching the flywheel period. What kind of starter is it?
