ideas to gain more lift, drier hull at speed.
Results 1 to 14 of 24
    Sacramento Ca.
    Default ideas to gain more lift, drier hull at speed.
    ive got a 74 tahiti, 468 olds with A2 impeller pushin 72 mph. Berk pump, jg bowl, PD droop, 2* up angle, and a diverter.
    At speed in the 3rd notch up on my diverter im runnin about 1/3 of my hull in the water. Id like to free that up a bit, possibly gaining some performance. Any of you veterans out there have any ideas i could try to free this thing up?
    opinions on the HTP snoot, and the adapt a shoe & ride plate kits would be nice as well. Id like to get my boat to ride right at the intake if possible. Ive seen many do it and like to get to that point.
    Feel free to chime in with anything im all ears. Looking for pics as i speak to show you how wet i ride lol...
    Matt 74 tahiti 468 olds 72 mph.
    http://img.photobucket.com/albums/v31/matt1840/sig.jpg
    Cas
    Cas is offline
    Angry American Cas's Avatar
    I'd try turning the wedge so you have 2º down, that's where mine works best.
    The pump itself should be set about 4º down, adding the droop with approx 8º up and then another 2 with the wedge it equates to a net 6º up. Having it that way will give a bigger rooster tail but it also causes the transom to be forced down into the water. The water flow with the up wedge is also having to bend more than what's desired.
    Turning the wedge over will help lift the back of the boat so you can then better adjust the attitude of the hull with the diverter
    Sacramento Ca.
    CAS MY MAN!
    how you been? comin up for NYD at cfw?? we have a 10 boat caravan heading out.. As for the 2* up i never thaught about the 4* intake set. If 4* is what its set at from factory for the tahiti ill try to take it out and see how it does. ill try without a wedge as well as ive never tried that. i always seem to think the intake is set at 0* to the keel.
    Cas
    Cas is offline
    Been doing well Matt, how about you?
    I doubt we'll be heading to CFW but there's always a chance.
    The bottom of the intake is set, or should be, to the bottom of the boat but the top of the intake has a wedge shape to it, higher on the engine side.
    Sacramento Ca.
    well it looks like i better start messin with some stuff. id like to get my mits on an adapt a shoe rideplate kit to help with my ride.. all in good time im gonna try some speed runs at the setting i have now, with 2* down then no wedge at all and see where my best results are and go from there add or minus some degree on the wedge... wheres that tach? LOL!
    Senior Member lowgear351's Avatar
    Jul 2009
    newcastle ca
    whear is your fuel tank or tanks? Saddel tanks in the rear are better than a bow tank.
    Sacramento Ca.
    Quote Originally Posted by lowgear351 View Post
    ive got a 10 gallon tank on each side of the hull that stretch from about 10" from the transom to just behind the driver and passanger seats.
    Senior Member JDG911's Avatar
    MESA
    Default have a staright snoot
    matt i have one pm me
    Quote Originally Posted by matt1840 View Post
    Your tahiti has a different deck than my old one. Maybe it has a different bottom too... My old one got a lil spooky around 70(on shut down). I'm not sure I'd want to try 80 in my old one. I'm no expert but getting it looser, may be a bad idea....I dunno. Again, your tahiti doesn't look like my old one.
    Cas
    Cas is offline
    If I remember correctly, yours had a Panther...totally different
    Not any more huh Kreg
    sorry for the thread Jack Matt
    I was just trying to help...you and I both know it didn't run 70 with a panther.
    Cas
    Cas is offline
    I didn't follow what you ended up doing to it? I know Tom ended up with it and put the conversion in it but never heard how it turned out? hell, I may even have all that wrong
    Matt heres a similar boat to yours (Apache) with setback Dominator (former Panther), runs 90+ looks sweet Tom
    Has ride plate (not sure what shoe now) droop and diverter
