swtd motor placement
Results 1 to 14 of 73
    Senior Member wajetboy's Avatar
    Auburn, WA
    Default swtd motor placement
    ok guys i am getting a jetaway soon so i was starting to wonder about motor placement so if i have to cut my driveshaft i only have to once. where is the best motor placement for my swtd? i have 800hp ford now but will be stepping up to 900hp with upto 500hp of spray within the next year. my motor is at 19" from the transom now.
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Angier, NC
    i'd go 23 24 have to play with it
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by wajetboy View Post
    if you're considering the back of the boat, not the pod, the transom, mine is 19" from the back of the block to the transom. i wouldn't change engine placement. it "looks" like your intake is in the normal location for a sw, with the back of the intake about 1" forward from the end of the pod.
    just install the jetaway on the pump, put the pump back in to get the measurement you want.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Dont move the engine, just cut the driveline to fit with the jet a way. wish i could get mine farther back. my intake is even with the pos but its only a 2" pod. I believe my engine is abot 22" from the transom. i will measure it to find out. it was a bitch to get the set up close with the engine forward. still more to do, but its cose.
    LHC
    when i installed the jetaway and had the engine in it, i just took the drive shaft and boat to the driveshaft shop, showed 'em where i wanted it and let them measure so they knew exactly where it needed to be cut. got it back the next day.
    Shell Knob, MO
    That's the best way to do it.
    Duane HTP
    mines at 20 inches transom to the rear plate, as far back as a top mount starter would allow. I have an extra 1310 driveline center piece, for a sw with jet-a-way. Measures 4 11/16 center to center.
    B1 Racing cs19's Avatar
    Why does everyone run the engine so far back in southwinds?
    Team CJ460 Just Electric's Avatar
    granada hills
    im guessing to get them to lift and not ride so wet jmo
    Mine was further back than presently, by a good five inches. I feel the boat rides/responds better now than before, but other things have been done since. Only been off the trailer three times or so, ran out of summer
    Auburn, WA
    ok sounds like the motor stays where it is. thanks everyone. i was going to cut the pod and set a lopro intake to get the hand hole out for a popoff but look like that wont be in the cards this year.
    Senior Member SlowRyd's Avatar
    Houston Tx.
    How does your boat ride (just cruising) with the engine that far forward does it have and odd characteristics?
    no, not really. i cant go any farther back. 22" to the plate.
    Houston Tx.
    thats good to hear Im going to set my motor at 20" to start with and go from there.
