hyd. divertor/ reverse bucket
Results 1 to 14 of 15
    Default hyd. divertor/ reverse bucket
    has ony one changed the reverse bucket on their hyd. divertors? the stock one on my s.d.309 suks, lookin for somethin with more control, been told the sdr split duct works great,, but not with the hyd. trim, any other ideas?
    Are we takin "Turbine trim" or Place diverter?
    uhhhh, im not sure what the difference is?? newbie here, the guy i talked to called it a hyd, trim when i bought it, could ya inform me on the difference? thanxs!!
    Charlotte, NC.
    Quote Originally Posted by show u one time View Post
    how about a picture of your set up if your not sure?
    X's 2
    California
    Place Diverter
    Turbine Trim
    California
    Sometimes a small bowl extension (2") can help reverse function, that helps keep the reverse thrust from getting trapped above the rideplate.
    Place Diverter
    Turbine Trim
    thanxs josh, ya i got the turbine trim, but what is the difference between the two? is one more for racin? And did i get the rite one for my use, the boat is not for racin, but for pissin around, its a 21 e6 eagle, so shes not no fast monster, just usein her for towin the kids and fishin, huntin type stuff. thanxs... mike.
    Both trim systems work very well and are quite similar in design , if you haven't expiremented you might try different up and down trim positions to see what positively effects your reverse action Also what Josh suggested, moving the steering back (spacer) I honestly think you have limited options (re the actual bucket) Tom
    California
    Truthfully it's probably a coin toss between the two as far a function, the Place Diverter is the more popular unit. The Turbine Trim requires it's own unique transitional housing, there for it will only work on Split Bowl equiped jets.
    As far as your reverse issue, you may try experimenting with the trim in various possitions while reversing. On my own boat, I found the reverse to be better with the trim in the max up position. This pointed the reverse chute just below the ride plate, rather than trapping it above.
    California
    you beat me, i was distracted
    While you were givin baby baths I was lurkin
    thanxs guys for the info,, now all i gotta do is wait till may, to stick the boat in the drink and go and try it out,, i hate winter!!!
    Fullerton, Ca.
    Cool Patented. Built in ride plate w/reverse
    Our reverse works fine, not as good as stock Berkeley, but hell, we concentrate on going forward....
