gel coat and paint stripper
Results 1 to 3 of 3
    Aug 2009
    Default gel coat and paint stripper
    does anyone know whethr or not paint /aircraft stripper affects the chemical composition of fiberglass...making it brittle,soft, or maybe more likley to delaminate...anything...any reason not to use it to strip the paint from my boat
    It will soften the gel. like anything, test in a small inconspicous area. work in small sections when you do find a combo that works.
    Southwest corner AR
    From what I have been told, it will not touch urathane (sp)paint! It will work on other paints and to apply in small amounts like 1.5' squares at a time! Don't let it stand to long either and keep water ready! Water is a neutralizer Apply in a small test area to see if it works for you! Good luck! WT
    WT
    WFL Crew!!!
