hate not B N blown
Results 1 to 13 of 13
hate not B N blown
    Jan 2010
    Default hate not B N blown
    Time for another up-grade...I need a blower set up for my 498..Im running a 76 hondo t-deck JET..so yes i need a lot more......WHAT CHA GOT
    Senior Member GRoper's Avatar
    you got the compression for it in that bad boy or are you using somethin else or differnt pistions?
    Jan 2010
    Default Huffer envy
    im running 10-5-1 with compresson pistons, full roller with merlin heads, dyno says 576 hp 640 trq,,,but its still a jet,,,a huffer and a new pump, just might make the day...
    Senior Member cave's Avatar
    Mesa, AZ
    Lotta work getting a blower mounted on a motor. Then theres the Pyro or AFR meters Fuel delivery bla bla bla. If I had it all over to do again I'd opted for more cubes inches and nice tunnel ram with Dominators on top.
    Now that the boat is blown I could never go back Just bigger on the huffer and maybe a 540-572. Alot of the OG boaters here give me crap on the surge but I like it.
    Many good ideas from people here on the boards if you go that route. If your gunna step into a blower get a real good fuel delivery pump. This killed me on the 1st build. Yup there were a few because I didn't listen to many on here.
    Make sure you can feed enough fuel to your new thirsty blower motor.
    get a good tune on your carbs or hat even if you need to pay someone to do it!
    Pyrometer or AFR gauge is a must so if you do go lean you can fix it right then before the boom
    A couple of jet kits for your boat that stay in the boat or pills for the hat. I was in Yuma and was running a tad lean. No jets lead to no fun... I left them in truck
    Last but prolly should be listed up top a dam good bottom end. Forged Crank, rods and definitely balanced! The right cam helps out to...
    Oh I almost forgot to warn you about the exhaust Valves. Inconel or superior.
    Good luck
    Takin it home
    Quote Originally Posted by shooter420 View Post
    put dat bitch on alky with a 8-71
    Jan 2010
    Great info all,,,thnx, but you know theres one thing i forgot to say is that all my buds have blown flatties..and damn it ,,i like my t-deck, so screw it ,its time to go big...;you can see on the water on the fourth of july at kings river in fresno.
    Mesa, AZ
    Well if your going big may I suggest PSI
    Takin it home
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    HERE YOU GO, JUST HAPPENS TO BE FOR SALE
    Jan 2010
    HOLY CRAP, THAT THING COME OFF A TOP FUEL..I THOUGHT ABOUT INJECTION, BUT I DONT WANT TO DEAL WITH TRYING TO DIAL IT IN EACH DAY,,,,WELL THATS WHAT I HEARD ANY WAY,,,
    Sep 2008
    DOME VALLEY,AZ
    I was going to put it on my river cruiser/ski boat this year, but i figured i am getting to old to try to go fast,
    Jan 2010
    what is it any way,,,just curious though,, how much ya want for it, also do ya know if carbs can be mounted instead of injection,,
    Mesa, AZ
    One of the many blowers that grace FARMER JOHNS shelves. Looks like a Performance System Inc. Blower
    or PSI Now that's going Big....
    Takin it home
    Senior Member zipper's Avatar
    Livermore,Ca
    Injection is one of the best thing's I put on my boat.
