Fuel pump
Results 1 to 5 of 5
Fuel pump
    Default Fuel pump
    I have a mild 460 with single A berk pump. Marine fuel pump on now and is starting to show wear(3-4 psi)Plugs looking lean. The third nipple is plugged off. Anyone have suggestions on new....I have a closed engine. Found this and I run a 3/8 line...http://www.summitracing.com/parts/SUM-250007-1/
    Made In The Shade
    Custom Window Tinting
    Member neverenuf's Avatar
    North Texas
    I've run this one on my 460 for the last five years with no problems. It's 120 [email protected] psi........ no regulator needed. They have a marine version also for closed eng compartments.
    http://cgi.ebay.com/ebaymotors/Carte...12017001r17082
    Has anyone here drilled and tapped the vent to run up to arrester on a non marine pump?
    Made In The Shade
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    "Nipple"
    B1 Racing cs19's Avatar
    Aeromotive 11203. Run a relay w/ it. Great pump
