Driveline
Results 1 to 6 of 6
Driveline
    Jul 2009
    Default Driveline
    How critical is it that the drivline be balanced between the motor and the jet? I know stupid question.
    I say that its important.
    boat owner says its not that important cause its so short.
    Just confirm this for me please. I figure it would trash bearings and seals,
    Jul 2009
    hello?
    i'm not trolling here....
    Dude...how big is you jet dl..?? What kind of dl do you have?? A pic might be a bonus..
    Los lunas NM
    Quote Originally Posted by Psycotic Break View Post
    If it spins it needs to be balanced. A little or alot it needs to be balanced.Water pumps starters altanatiors ect are all balanced. IMO if it spins balance it.Just my .02 cents
    Nov 2009
    Langley, B.C. Canada
    I'd agree with that, you can get harmonic vibrations from unbalanced items, not that i have seen it in jet drive lines but i have seen it else where
    Senior Member lbhsbz's Avatar
    Long Beach
    Balancing is always a good idea, but a minor imbalance will not affect much if the distance between the supporting bearings is small. Even my 18" driveline looks way out of wack, but because of the small diameter and relatively short length...it required very little to balance it.
    Balancing becomes much more critical with longer unsupported distances and larger diameters. Most jet drivelines are too short I'd think to really matter. I've built my own 18-20" drivelines on hot rods and didn't balance them...no vibration at all...but small imbalance on a 60" driveline or on a 14" brake rotor will rattle your teeth out
