6AL ing.mount
Results 1 to 14 of 15
6AL ing.mount
    Senior Member lv4jetboats's Avatar
    fernley nevada
    Default 6AL ing.mount
    Dose anyone have any pics on mounting.Dont know where to put it stringers or motor thank you
    put it somewhere it doesn't get wet, alot of guys around here put them on the bulkhead under the dash
    #55
    fernley nevada
    I was thinking about making a braket and mounting to stringer under the bow
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    Quote Originally Posted by lv4jetboats View Post
    Should be fine there, but X2 on keeing it out of water. Don't ever mount them on the engine if you can help it! The vibrations and harmonics will kill it quick!
    Ray
    Senior Member Xerophobic's Avatar
    Calgary, Alberta, Canada
    Never had an issue, well, when the boat sank but...
Name:	Grabbed Frame 3.JPG
    If you ain't hittin bottom...you ain't jetboatin!
    Here mine from my flatty :
    Got Circus Midgets??? BIGAMIST's Avatar
    S.F.V.
    I know my picture is showing you a fuel filter, but I mounted my MSD box to the same piece of aluminum just on the other side of the pump.
    When I die I want to go nice and peaceful in my sleep like Grandpa did, not screaming like the other passengers in His car.
    Charlotte, NC.
    Quote Originally Posted by Xerophobic View Post
    Did it still work after sinking?
    Colfax, Ca
    haha actually it did! we did the fast oil change etc etc and the motor would fire up but it was kinda weird, anything other than idle would stumble and die. At first I thought the box had actually survived but when we put a 2nd box on it ran fine so....
    Member blownt's Avatar
    Houston, Texas
    this is what I am doing on mine. Got four 1" dia aluminum rods drilled and tapped and glassed to the floor. And 3/8" aluminum plate mounting battery and MSD.
ID:	64456   Click image for larger version.
    Senior Member lbhsbz's Avatar
    Long Beach
    That's funny. I had 2 brand new boxes fail on me...the one that's in the boat now is a used loaner that's been sunk at least once...its been reliable so far. Maybe I'll dump the other 2 in a bucket of water and see if they start working again. LOL
    Silverdale, Washington
    I mounted mine as high as I could (which isnt very high on my boat) on the transom under the deck so it's out of the splash zone and well protected. Been like that for probably 7 years with no issues.
